EPS.00.250.NTN
EPS.00.250.NTN
    LEMO(雷莫)
    EPS.00.250.NTN
EPS.00.250.NTN 数据手册
EPS.00.250.NTN www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Female print PCB IP rating 50 AWG wire size 0.00 - 0.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Matching parts FVS.00.250.NTA Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model EPS*: Elbow receptacle with two nuts, for printed circuit Keying Circular, female Housing Material Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces Weight 5.45 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Printed Circuit Board) Contact Dia.: 0.7 mm (0.028in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >144 hr DRAWINGS Dimensions A L e mm. 7 17.5 M7x0.5 in. 0,28 0,69 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.00.M07.4 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
EPS.00.250.NTN 价格&库存
很抱歉,暂时无法提供与“EPS.00.250.NTN”相匹配的价格&库存,您可以联系我们找货
EPS.00.250.NTN
    • 1+126.096881+16.18890
    • 10+121.6709710+15.62068
    • 25+113.6918625+14.59628
    库存:46
    EPS.00.250.NTN
      • 1+152.398731+19.56565
      • 10+147.0439510+18.87818
      • 25+137.4087025+17.64116
      库存:46
