CONREVSMA011
CONREVSMA011
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
CONREVSMA011 数据手册
Description Body Pin Insulation Gasket Crimp Ring Heat Shrink Material Brass Brass PTFE SI Rubber Brass Polyolefin Finish Nickel Gold N/A Rubber Nickel Black REVISIONS REV B DESCRIPTION Updated footprint and dimensions; Added new title block DATE APPV 2-JUL-12 SAH Ø0.154 [3.90] 1/4-36UNS-2A THREADS 0.374 [9.50] 0.339 [8.60] Ø0.209 [5.30] 0.106 [2.70] CRIMP RING Ø0.049 [1.25] H0.252 [6.40] PIN 0.252 [6.40] Ø0.197 [5.00] 0.197 [5.00] 0.571 [14.50] 0.787 [20.00] SIDE VIEW HEAT SHRINK CONREVSMA011 ASSEMBLY INSTRUCTIONS 1. 2. 3. 4. 5. 6. Strip cable to recommended dimensions. Slip heat shrink and crimp ring onto stripped cable. Solder the pin to the center conductor. Insert the pin, center conductor, and insulator into the body. Wrap the braid around the tail of the body and crimp the ring with a 0.128" hex crimp tool (or one labeled for use with RG-174 cable). Use heat shrink to cover crimp. 0.098 0.033 [2.50] [0.85] 0.177 [4.50] RG-174 Cable : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: RECOMMENDED CABLE STRIPPING DIMENSIONS NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 DRAWN: B.MURPHY DT: 2-JUL-12 ENGR: S.HOGAN DT: 2-JUL-12 TITLE: 159 ORT LANE MERLIN, OR 97532 RP-SMA FEMALE CABLE END CRIMP FOR RG-174 CABLE SIZE DWG. NO. REV CONREVSMA011 B SCALE: 2:1 DO NOT SCALE DRAWING SHEET 1 OF 1 LDCFDLT_A
CONREVSMA011
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制、医疗电子等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
CONREVSMA011 价格&库存
很抱歉,暂时无法提供与“CONREVSMA011”相匹配的价格&库存,您可以联系我们找货
