CONSMA007-R178
CONSMA007-R178
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    SMA
CONSMA007-R178 数据手册
Description Body Pin Insulation Spacer Gasket Support Heat Shrink Material Brass Be Cu PTFE PTFE Si Rubber Be Cu Polyolefin Finish Nickel Gold N/A N/A N/A Gold Black REVISIONS 0.146 [3.70] 0.197 [5.00] REV RG-178 Cable DESCRIPTION DATE APPV 2-JUL-12 SAH B Updated footprint and dimensions; Added new title block C Updated stripping dimensions; Added dimensions to spacer 12-JUN-13 and support SAH 0.228 [5.80] RECOMMENDED CABLE STRIPPING DIMENSIONS 0.039 [1.00] 0.327 [8.30] H0.315 [8.00] Ø0.106 [2.70] 1/4-36UNS-2B THREADS Ø0.035 [0.90] 0.197 [5.00] 0.252 [6.40] Ø0.053 [1.35] 0.098 [2.50] SPACER SUPPORT PIN Ø0.118 [3.00] 0.591 [15.00] SIDE VIEW 0.787 [20.00] HEAT SHRINK NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. CONSMA007-R178 ASSEMBLY INSTRUCTIONS 1. 2. 3. 4. 5. 6. 7. 8. Strip cable to recommended dimensions. Slip heat shink onto cable. Solder support onto the braid. Place the spacer onto the center conductor. Solder or crimp the pin onto the center conductor. Insert the pin, center conductor, spacer and support into the body until the top of the socket is even with the threaded opening in the body. Crimp the tail of the body onto the support with a 0.093” hex crimp tool (or one labeled for use with RG-178 cable). Use heat shrink to cover crimp. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 DRAWN: B.MURPHY DT: 2-JUL-12 ENGR: S.HOGAN DT: 2-JUL-12 TITLE: 159 ORT LANE MERLIN, OR 97532 SMA MALE CABLE END CRIMP FOR RG-178 CABLE SIZE DWG. NO. CONSMA007-R178 SCALE: 2:1 DO NOT SCALE DRAWING REV C SHEET 1 OF 1 LDCFDLT_A
CONSMA007-R178 价格&库存
很抱歉,暂时无法提供与“CONSMA007-R178”相匹配的价格&库存,您可以联系我们找货
