CONMCX011
CONMCX011
    LINXTECHNOLOGIES(灵思)
    MCX
CONMCX011 数据手册
Description Body Socket Insulation Crimp Ring Heat Shrink Material Brass BE CU PTFE Brass Polyolefin Finish Gold Gold N/A Gold Black REVISIONS SIDE VIEW REV DESCRIPTION DATE APPV B C Added new title block and heat shrink; updated instructions 11-JUL-12 SAH Updated Assembly Instruction 4 and Note 3 2-NOV-17 CLL CRIMP RING SOCKET Ø0.154 [3.90] PIN CHUCK 0.2x2x2 GROOVE Ø0.197 [5.00] Ø0.102 [2.60] 0.244 [6.20] Ø0.037 [0.95] 0.276 [7.00] 0.382 [9.70] HEAT SHRINK 0.575 [14.60] Ø0.197 [5.00] CONMCX011 ASSEMBLY INSTRUCTIONS 1. 2. 3. 4. 5. 6. Strip cable to recommended dimensions. Slip heat shrink and crimp ring onto stripped cable. Solder the socket to the center conductor. Insert the socket and center conductor into the body until the socket snaps in. Wrap the braid around the tail of the body and crimp the ring with a 0.128” hex crimp tool (or one labeled for use with RG-174 cable). Use heat shrink to cover crimp. RECOMMENDED CABLE STRIPPING DIMENSIONS 0.079 [2.00] 0.102 [2.60] 0.189 [4.80] RG-174 Cable 0.787 [20.00] NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE, USE MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE SOURCED MATERIALS. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 159 ORT LANE MERLIN, OR 97532 TITLE: MCX FEMALE CABLE END CRIMP FOR RG174 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 11-JUL-12 ENGR: S.HOGAN DT: 11-JUL-12 SCALE: 2:1 REV CONMCX011 DO NOT SCALE DRAWING C SHEET 1 OF 1 LDCFDLT_A
CONMCX011 价格&库存
很抱歉,暂时无法提供与“CONMCX011”相匹配的价格&库存,您可以联系我们找货
