Description
Body
Pin
Insulation
Crimp Ring
Boyd Chuck
Insulator
Cover
Heat Shrink
Material
Brass
Brass
PTFE
Brass
BE CU
PTFE
Brass
Polyolefin
Finish
Gold
Gold
N/A
Gold
Gold
N/A
Gold
Black
REVISIONS
HEAT SHRINK
REV
B
Ø0.197
(5.00)
DESCRIPTION
Added new title block, heat shrink and instructions
DATE
APPV
12-JUL-12
SAH
CRIMP RING
Ø0.154
(3.90)
0.787
(20.00)
TOP VIEW
SIDE VIEW
0.079 0.035
(2.00) (0.90)
BOYD CHUCK
0.3x3.9x5mm GROOVE
0.276
(7.00)
COVER
INSULATOR
Ø0.148
(3.75)
0.394
(10.00)
CONMCX012 ASSEMBLY INSTRUCTIONS
1. Strip the cable to the recommended dimensions.
2. Slip heat shrink and crimp ring onto stripped cable.
2. Slide the cable into the body until the center conductor is centered in the fork.
3. Push the braided shield over the barrel.
4. Solder the center conductor into the center of the fork.
5. Slide the crimp ring over the shield and crimp with a 0.128” hex crimp tool
(or one labeled for use with RG-174 cable).
6. Trim off any excess shield wire sticking out from the ring.
7. Slip the heat shrink over the crimp ring until it is against the body and shrink.
8. Insert insulator into body.
9. Push the cover into the opening.
NOTES: (UNLESS OTHERWISE SPECIFIED)
1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE.
2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM.
: THIS DRAWING CONTAINS PROPRIETARY INFORMATION
159 ORT LANE
0.165
(4.20)
Ø0.102
(2.60)
0.339
(8.60)
RECOMMENDED CABLE STRIPPING DIMENSIONS
0.138
(3.50)
0.197
(5.00)
RG-174 Cable
THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE
TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS
DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE
EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS
DESIGNATED AGENTS.
MATERIAL:
BRAIDED SHIELD
0.035
(0.90)
0.173
(4.40)
0.197
(5.00)
0.031
(0.80)
Ø0.157
(4.00)
0.171 0.197
(4.35) (5.00)
FINISH:
PROJECTION:
TOLERANCES:
.020 [0.50]-.200 [5.00]= .008 [0.20]
.200 [5.00]-1.200 [30.00]= .016 [0.40]
1.20 [30.0]-4.75 [120.0]= .024 [0.60]
4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1
TITLE:
MERLIN, OR 97532
MCX MALE RIGHT ANGLE
CABLE END CRIMP FOR RG174 CABLE
SIZE DWG. NO.
DRAWN: B.MURPHY DT: 12-JUL-12
ENGR: S.HOGAN
DT: 12-JUL-12 SCALE: 2:1
REV
CONMCX012
DO NOT SCALE DRAWING
B
SHEET 1 OF 1
LDCFDLT_A
很抱歉,暂时无法提供与“CONMCX012”相匹配的价格&库存,您可以联系我们找货
