CONMMCX012-R178
CONMMCX012-R178
    LINXTECHNOLOGIES(灵思)
CONMMCX012-R178 数据手册
Description Body Pin Insulation Crimp Ring Boyd Chuck Insulator Cover Heat Shrink Material Brass Brass PTFE Brass BE CU PTFE Brass Polyolefin Finish Gold Gold N/A Gold Gold N/A Gold Black REVISIONS REV B C DESCRIPTION DATE New frame; added heat shrink Added new title block; Revised instructions APPV 7/27/09 CJ 11-JUL-12 BPM HEAT SHRINK Ø0.118 (3.00) SIDE VIEW 0.787 (20.00) 0.270 (6.85) 0.104 (2.65) CRIMP RING 0.138 (3.50) Ø0.126 (3.20) COVER INSULATOR Ø0.093 (2.35) 0.276 (7.00) 0.354 (9.00) CONMMCX012-R178 ASSEMBLY INSTRUCTIONS 1. Strip the cable to the recommended dimensions. 2. Slip heat shrink and crimp ring onto stripped cable. 2. Slide the cable into the body until the center conductor is centered in the fork. 3. Push the braided shield over the barrel. 4. Solder the center conductor into the center of the fork. 5. Slide the crimp ring over the shield and crimp with a 0.100” hex crimp tool. 6. Trim off any excess shield wire sticking out from the ring. 7. Slip the heat shrink over the crimp ring until it is against the body and shrink. 8. Insert insulator into body. 9. Push the cover into the opening. 0.197 (5.00) Ø0.079 (2.00) NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE RECOMMENDED CABLE STRIPPING DIMENSIONS 0.028 0.059 (0.70) (1.50) 0.217 (5.50) RG-174 Cable THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: BRAIDED SHIELD FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 DRAWN: CJ ENGR: DT: 7/27/09 DT: TITLE: MERLIN, OR 97532 MMCX MALE RIGHT ANGLE CABLE END CRIMP FOR RG178 CABLE SIZE DWG. NO. REV CONMMCX012-R178 SCALE: 2:1 DO NOT SCALE DRAWING C SHEET 1 OF 1 LDCFDLT_A
CONMMCX012-R178 价格&库存
很抱歉,暂时无法提供与“CONMMCX012-R178”相匹配的价格&库存,您可以联系我们找货
