Description
Body
Socket
Insulation
Nut
Washer
Heat Shrink
Support
Spacer
Material
Brass
BE CU
PTFE
Brass
Brass
Polyolefin
Brass
PTFE
Finish
Gold
Gold
N/A
Gold
Gold
Black
Gold
N/A
REVISIONS
RECOMMENDED MOUNTING
HOLE
REV
B
DESCRIPTION
DATE
Added new title block and heat shrink; Updated instructions 11-JUL-12
SAH
HEAT SHRINK
FLAT 0.173
(4.40)
Ø0.118
(3.00)
SIDE VIEW
10-56 UNS-2A
THREADS
APPV
Ø0.187
(4.75)
H0.250
(6.35)
FLAT 0.173
(4.40)
0.787
(20.00)
SOCKET
PIN CHUCK
0.2x2x2 GROOVE
Ø0.106
(2.70)
0.244
(6.20)
SPACER
SUPPORT
Ø0.037
(0.95)
CONREVMCX005-R178 ASSEMBLY INSTRUCTIONS
0.272
(6.90)
0.378
(9.60)
NUT
WASHER
0.571
(14.50)
H0.250
(6.35)
7.
Ø0.377
(9.57)
8.
9.
10-56 UNS-2B
THREADS
0.055
(1.40)
RECOMMENDED CABLE STRIPPING DIMENSIONS
0.138 0.024
(3.50) (0.60)
0.197
(5.00)
RG-178 Cable
1.
2.
3.
4.
5.
6.
0.020
(0.50)
Strip the cable to the recommended dimensions.
Slip heat shrink onto the stripped cable.
Solder the support onto the braid.
Place the spacer onto the center conductor.
Solder or crimp the socket onto the center conductor.
Insert the socket, center conductor, spacer, and support into
the body until the socket snaps in.
Crimp the tail of the body onto the support with a 0.093”
hex crimp tool (or one labeled for use with RG-178 cable).
Use heat shrink to cover crimp.
Use the nut and washer to secure the connector to a case.
NOTES: (UNLESS OTHERWISE SPECIFIED)
1. ALL DIMENSIONS ARE IN INCHES [mm].
2. DIMENSIONS APPLY AFTER FINISHING.
3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE.
4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM.
: THIS DRAWING CONTAINS PROPRIETARY INFORMATION
THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE
TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS
DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE
EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS
DESIGNATED AGENTS.
MATERIAL:
FINISH:
PROJECTION:
TOLERANCES:
.020 [0.50]-.200 [5.00]= .008 [0.20]
.200 [5.00]-1.200 [30.00]= .016 [0.40]
1.20 [30.0]-4.75 [120.0]= .024 [0.60]
4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1
TITLE:
159 ORT LANE
MERLIN, OR 97532
MCX FEMALE BULKHEAD MOUNT
CABLE END CRIMP FOR RG178 CABLE
SIZE DWG. NO.
DRAWN: B.MURPHY DT: 11-JUL-12
ENGR: S.HOGAN
DT: 11-JUL-12 SCALE: 2:1
REV
CONMCX005-R178
DO NOT SCALE DRAWING
B
SHEET 1 OF 1
LDCFDLT_A
很抱歉,暂时无法提供与“CONMCX005-R178”相匹配的价格&库存,您可以联系我们找货
