CP1094-U
CP1094-U
    CINCH
    CONN BNC JACK STR 50 OHM SOLDER
CP1094-U 数据手册
5 4 3 2 1 DRAWING NO. CP1094U-CUST REVISIONS D Description: BNC,Front Mount Bulkhead Jack, BeCu Contact Part No: CP1094U Application: PCB Crimp Tool: N/A Impedance: OFFICIAL RELEASE 01 03-20-09 02 50 Ohms Material: Body 03 Brass Nickel plated Insulotor Teflon C Nut Brass 04 Nickel plated Lock Washer D T Y G Y G M L LOCK WASHER MATERIAL WAS BRASS ADD MORE DIMENSIONS 07-27-11 Contact Becu Gold plated B Y RELEASE FOR SUPPLIER ALTER 07-27-11 Frequency Range: 0-4 GHz T W Y G Y G M L ECO-11-0270 3/8-32UNEF WAS 3/8-32UNEF-2A 01-11-12 Y G Y G M L S50C Nickel plated lma 2012.01.11 11:11:06 +08'00' C ECO-12-0008 RoHS Compliance: Yes Technical Detail: Refer to Emerson Document P/N 27-0000 12.7 .500in 26.70 ±0.5 1.051in ±.020 3/8-32 UNEF 3.92 .154in 12.0 .472in 2.0 .079in B B 2.13 .084in O O 1.52 .060in 20.0 .787in RECOMMENDED MOUNTING HOLE DIMENSIONS O 9.7 .382in DIM OUTLINE A CUSTOMER COPY TOLERANCE UNLESS DRAWN BY OTHERWISE SPECIFIED YUGE HU DATE DECIMALS DATE X X.X X.XX ANGLES 8.9 .350in 5 mm CHECKED BY +- 0.5 +- 0.2 +- 0.1 +- 0.5v YUGE HU 07-27-11 APPROVED BY DATE LIN MA U/M 3 TITLE 07-27-11 mm THIS DRAWING WAS PRODUCED BY COMPUTER, DO NOT SCALE DRAWING OR UPDATE MANUALLY. 4 Connectivity Solutions 07-27-11 2 A BNC,FRONT MOUNT BULKHEAD JACK, BECU CONTACT SHEET 1 OF 1 SIZE DRAWING NO. A CP1094U-CUST 1
CP1094-U 价格&库存
很抱歉,暂时无法提供与“CP1094-U”相匹配的价格&库存,您可以联系我们找货
