CONREVSMA014
CONREVSMA014
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
CONREVSMA014 数据手册
Description Body Pin Insulation O Ring Crimp Ring Washer Nut Heat Shrink 1/4-36UNS-2B THREADS Material Brass Brass PTFE Si Rubber Brass Brass Brass Polyolefin Finish Nickel Gold N/A Rubber Nickel Nickel Nickel Black REVISIONS 0.236 [6.00] REV Ø0.256 [6.50] Ø0.020 [0.50] RECOMMENDED MOUNTING HOLE DESCRIPTION B C Updated dimensions and instructions; Added title block Updated pin look and dim. ; Updated crimp ring dim. Ø0.024 [0.60] 0.400 [10.16] Ø0.154 [3.90] Ø0.197 [5.00] 0.787 [20.00] 0.355 [9.02] HEAT SHRINK CRIMP RING 0.197 [5.00] 0.083 [2.10] FLAT 0.228 [5.80] Ø0.236 (6.00) 0.248 [6.30] 0.748 [19.00] Ø0.358 [9.10] Ø0.402 [10.20] H0.315 [8.00] 1/4-36UNS-2B THREADS SIDE VIEW 0.138 [3.50] 0.177 [4.50] SAH SAH Ø0.049 [1.24] H0.433 [11.00] Ø0.102 Ø0.236 [6.00] [2.60] 0.098 [2.50] APPV PIN FLAT 0.228 [5.80] 0.417 [10.60] DATE 10-JUL-12 29-OCT-12 0.433 [11.00] RG-174 Cable RECOMMENDED CABLE STRIPPING DIMENSIONS BACK VIEW 0.055 [1.40] 0.065 [1.65] O-RING NUT 0.020 [0.50] WASHER NOTES: (UNLESS OTHERWISE SPECIFIED) 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 1. ALL DIMENSIONS ARE IN INCHES [mm]. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. 2. DIMENSIONS APPLY AFTER FINISHING. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE CONREVSMA014 ASSEMBLY INSTRUCTIONS THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE 1. Strip cable to recommended dimensions. MERLIN, OR 97532 TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS 2. Slip heat shrink and crimp ring onto stripped cable. DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE TITLE: 3. Solder the pin to the center conductor. EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS RP-SMA FEMALE, BULKHEAD MOUNT, CABLE DESIGNATED AGENTS. 4. Insert the pin, center conductor, and insulation into the body. PROJECTION: MATERIAL: TOLERANCES: END CRIMP WITH O-RING FOR RG174 CABLE 5. Wrap the braid around the tail of the body and crimp the ring with .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 0.128" hex crimp tool (or one labeled for use with RG-174 cable). 1.20 [30.0]-4.75 [120.0]= .024 [0.60] SIZE DWG. NO. REV 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 6. Use heat shrink to cover crimp. CONREVSMA014 FINISH: C DRAWN: B.MURPHY DT: 10-JUL-12 7. Use the nut and washer to secure the connector to a case. (2.50mm maximum wall thickness) DO NOT SCALE DRAWING SHEET 1 OF 1 ENGR: S.HOGAN DT: 10-JUL-12 SCALE: LDCFDLT_A
CONREVSMA014 价格&库存
很抱歉,暂时无法提供与“CONREVSMA014”相匹配的价格&库存,您可以联系我们找货
