CP1094AST
CP1094AST
    CINCH
    CONN BNC JACK STR 50 OHM SOLDER
CP1094AST 数据手册
50 Ohm BNC Front Mount Bulkhead Jack Receptacle With Solder Tab INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST CP-1094-AST Mounting hole layout Cambridge Products, P.O. Box 1732, Waseca, MN 56093-0832 • 1-800-243.8814 • Fax: 507-833-6287 • www.cambridgeproducts.com BNC Connectors Specifications INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST The BNC series connector is a commercial quality product that intermates with all standard double bayonet stud BNC designs. All contacts are captivated for ruggedness. The 50 ohm and 75 ohm interfaces are intermateable and provide quick, reliable connections for instrumentation, medical and LAN applications. Specifications* 50 Ohm BNC Electrical Characteristics Impedance: 50 Ohm nominal Frequency range: 0-4 GHz Working voltage: 500 volts RMS at sea level Dielectric withstanding voltage: 1500 volts RMS at sea level Corona level: 375 volts minimum at 70,000 feet Contact resistance: Outer - 0.2 milliohms maximum Center - 2.1 milliohms maximum Insulation resistance: 5000 megohms minimum Environmental Characteristics Recommended temperature range: -55OC to +85OC Moisture resistance: MIL-STD-202 Mechanical Characteristics Durability: 500 cycles Force to engage/disengage: 3 lbs. maximum Cable retention: 20 lbs., RG-58 C/U cable Materials Body: Zinc or brass Contact: Brass, beryllium copper or phosphor bronze Spring Washer: Beryllium copper Crimp sleeve: Brass Insulator: Delrin® or TPX Polymethylpentene Plating: Body - Nickel (except where noted) Crimp sleeve - Nickel Contact - Gold * These values are typical and may not apply to all connectors. Cambridge Products, P.O. Box 1732, Waseca, MN 56093-0832 • 1-800-243.8814 • Fax: 507-833-6287 • www.cambridgeproducts.com
CP1094AST 价格&库存
很抱歉,暂时无法提供与“CP1094AST”相匹配的价格&库存,您可以联系我们找货
