CONSMA014
CONSMA014
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    SMA
CONSMA014 数据手册
Description Body Socket Insulation O-Ring Crimp ring Washer Nut Heat Shrink 1/4-36UNS-2A THREADS Material Brass Brass PTFE Si Rubber Brass Brass Brass Polyolefin Finish Nickel Gold N/A Rubber Nickel Nickel Nickel Black 0.098 [2.50] 0.138 [3.50] REVISIONS 0.177 [4.50] REV RG-174 Cable B C DESCRIPTION DATE APPV Updated dimensions; Added new title block 10-JUL-12 SAH Updated socket look and dim.; Updated crimp ring dim. 29-OCT-12 SAH Ø0.197 [5.00] RECOMMENDED CABLE STRIPPING DIMENSIONS FLAT 0.228 [5.80] PIN CHUCK Ø0.020 0.2x2x2mm GROOVE [0.50] H0.433 [11.00] Ø0.102 [2.60] Ø0.236 [6.00] 0.787 [20.00] Ø0.024 Ø0.049 [0.60] [1.24] 0.310 [7.87] HEAT SHRINK Ø0.154 [3.90] SOCKET 0.197 (5.00) 0.417 [10.60] 0.083 [2.10] 0.248 [6.30] Ø0.236 (6.00) 0.748 [19.00] Ø0.358 [9.10] Ø0.402 [10.20] SIDE VIEW 0.055 [1.40] 0.065 [1.65] O-RING NUT CRIMP RING 0.234 [6.00] H0.315 [8.00] 1/4-36UNS-2B THREADS 0.355 [9.02] Ø0.256 [6.50] 0.020 [0.50] WASHER RECOMMENDED MOUNTING HOLE NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE CONSMA014 ASSEMBLY INSTRUCTIONS 1. Strip the cable to recommended dimensions. THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE 2. Slip heat shrink and crimp ring onto stripped cable. MERLIN, OR 97532 TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS 3. Insert o-ring into groove in the nut on body. DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE TITLE: 4. Solder the socket to the center conductor. EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS SMA FEMALE BULKHEAD MOUNT CABLE DESIGNATED AGENTS. 5. Insert the socket, center conductor, and insulation into the body. PROJECTION: MATERIAL: TOLERANCES: END CRIMP WITH O-RING FOR RG174 CABLE 6. Wrap the braid around the tail of the body and crimp the ring with .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 0.128" hex crimp tool (or one labeled for use with RG-174 cable). 1.20 [30.0]-4.75 [120.0]= .024 [0.60] SIZE DWG. NO. REV 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 7. Use heat shrink to cover crimp. FINISH: CONSMA014 C 8. Use the nut and washer to secure the connector to a case. DRAWN: B.MURPHY DT: 10-JUL-12 (2.50mm maximum wall thickness) DO NOT SCALE DRAWING SHEET 1 OF 1 ENGR: S.HOGAN DT: 10-JUL-12 SCALE: 2:1 LDCFDLT_B
CONSMA014 价格&库存
很抱歉,暂时无法提供与“CONSMA014”相匹配的价格&库存,您可以联系我们找货
