CONSMA015
CONSMA015
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    SMA
CONSMA015 数据手册
Description Body Socket Insulation Crimp Ring O Ring Washer Nut Heat Shrink H0.433 (11.00) Material Brass BE CU PTFE Brass SI Rubber Brass Brass Polyolefin Finish Nickel Gold N/A Nickel Rubber Nickel Nickel Black 0.098 (2.50) REVISIONS 0.177 (4.50) REV RG-174 Cable B C DESCRIPTION DATE APPV Add assembly instructions and heat shrink 1/8/10 CJ Updated dimensions; Added new title block 10-JUL-12 BPM Ø0.197 (5.00) RECOMMENDED CABLE STRIPPING DIMENSIONS 1/4-36UNS-2A THREADS 1/4-36UNS-2A THREADS 0.134 (3.40) FLAT 0.228 (5.80) PIN CHUCK 0.2x2x2 GROOVE Ø0.102 (2.60) Ø0.020 (0.50) 0.787 (20.00) Ø0.024 Ø0.049 (0.60) (1.24) 0.587 (14.90) HEAT SHRINK Ø0.154 (3.90) SOCKET 0.228 (5.80) 0.083 (2.10) 0.472 (12.00) Ø0.402 [10.20] 0.980 (24.90) SIDE VIEW Ø0.236 (6.00) Ø0.358 (9.10) 0.065 [1.65] NUT CONSMA015 ASSEMBLY INSTRUCTIONS Ø0.256 [6.50] 0.020 [0.50] WASHER RECOMMENDED MOUNTING HOLE NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE 0.055 (1.40) O-RING CRIMP RING 0.234 [6.00] H0.315 [8.00] 1/4-36UNS-2B THREADS 0.374 (9.50) THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: 1. Solder the socket to the center conductor or crimp with 0.028” hex crimp tool. 2. Insert the socket, center conductor, and insulation into the body. 3. Wrap the braid around the tail of the body and crimp the ring with a FINISH: 0.128" hex crimp tool (or one labeled for use with RG-174 cable). 4. Slide heat shrink tubing over crimp ring and then heat. PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: MERLIN, OR 97532 SMA FEMALE BULKHEAD MOUNT CABLE END CRIMP WITH O-RING FOR RG174 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 10-JUL-12 ENGR: S.HOGAN DT: 10-JUL-12 SCALE: 2:1 REV CONSMA015 DO NOT SCALE DRAWING C SHEET 1 OF 1 LDCFDLT_A
CONSMA015 价格&库存
很抱歉,暂时无法提供与“CONSMA015”相匹配的价格&库存,您可以联系我们找货
