MMCX Straight Plug for .047 (1.19) Diameter and RG-178 Size Flexible Cablev
1. Identify piece parts. (3 piece parts)
2. Strip cable jacket to dimensions shown. Do not nick braid
or center conductor during strip operations.
3. Slide crimp insert over braid and against jacket. Fold
braid around crimp insert as shown. Strip dielectric to
dimension shown. Tin center conductor if contact is to be
soldered attached. Do not tin center conductor if contact
is to be crimp attached.
4. Assemble contact assembly onto cable as shown.
Solder attachment: Solder contact to center conductor.
Care should be taken that excess solder is not applied.
Crimp attachment: Crimp contact to center conductor
using Johnson hand tool 140-0000-952 and die set 140000-953. Crimp location should be centered between
and of contact and cross-hole. Crimp attachment to solid
center conductor cables is not recommended.
5. Slide body assembly over contact and crimp insert, then
seat firmly as shown. Crimp body using recommended
crimp die hex. Maintain forward pressure on cable while
crimping.
Cable
Group
Part No.
Strip
Length
Crimp Hex
.047 Flexible
135-3436-001
.135 (3.43)
.105 (2.67) x .250 (6.35) W
RG-178/U, 196
135-3402-001
.184 (4.67)
222
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“135-3436-001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+92.293911+11.99383
- 10+78.4594110+10.19600
- 25+73.5448225+9.55734
- 50+70.0325350+9.10091
- 100+66.68970100+8.66650
- 250+62.51584250+8.12410
- 500+62.28132500+8.09362
- 1000+58.756041000+7.63550
- 国内价格 香港价格
- 1+81.922701+10.43390
- 10+69.6431010+8.86990
- 25+63.3691025+8.07090
- 50+61.3983050+7.81990
- 100+59.06600100+7.52280
- 250+55.20600250+7.03120
- 1000+53.783301000+6.85000
