133-3693-101
133-3693-101
    CINCH
    MCX
133-3693-101 数据手册
MCX Solder Type Straight Plug for Semi-Rigid Cable 1. Identify connector parts. (2 piece parts) 2. Strip cable to dimensions shown. Do not nick center conductor. 3. Place center contact on center conductor making sure contact bottoms against cable insulation. Solder center conductor to center contact through solder hole. Solder must not be allowed to run on outside of contact. Use a minimum amount of solder for a good joint. .020 (0.51) diameter solder is recommended. Trim excess insulation. 4. Insert contact and cable into body assembly making sure cable is bottomed against insulator in body. Solder body to cable. Use a minimum amount of heat to minimize cable insulation movement. Cable Group Part No. RG-405/U (.086 Semi-Rigid) 133-3693-001 133-3693-006 MCX Solder Type Right Angle Plug for Semi-Rigid Cable 1. Identify connector parts. (3 piece parts) 2. Strip cable to dimensions shown. Do not nick center conductor. 3. Insert cable into body making sure cable insulation bottoms on center contact. Solder center conductor to contact through the rear access port. Use a minimum amount of solder for a good joint. .020 (0.51) diameter solder is recommended. 4. Solder body to cable. Use a minimum amount of heat to minimize cable insulation movement. Assemble insulator then place expansion cap in access port and seat with a .156 (3.96) diameter punch or hand tool 141-0000-908. Cable Group Part No. RG-405/U (.086 Semi-Rigid) 133-3693-101 226 133-3693-106 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
133-3693-101 价格&库存
很抱歉,暂时无法提供与“133-3693-101”相匹配的价格&库存,您可以联系我们找货
