131-1403-001
131-1403-001
    CINCH
    SMB Connector Plug, Female Socket 50 Ohm Free Hanging (In-Line) Solder
131-1403-001 数据手册
SMB/SMC/Mini-75Ohm SMB (2-Piece) Crimp Type Straight Plugs, Jacks and Bulkhead Jacks for Flexible Cable 1. Identify connector parts. (2 piece parts – except bulkhead) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin. Slide crimp sleeve onto cable as shown. 3. Flare braid and slide cable into body making certain that the cable dielectric bottoms against center contact. Solder Attachment: Solder center conductor to contact through the side access ports and hole in center contact. Use a minimum amount of solder for a full fillet joint. .020 (0.51) diameter solder is recommended. Crimp Attachment: Crimp applicable 50 Ohm connector contacts with 141-0000-911 dieset in 144-0000-900 tool frame. Crimp 75 Ohm connector contacts with 141-0000-924 dieset in 144-0000-900 tool frame. Crimp attachment to solid center conductor cables is not recommended. Cable Group Part No. Crimp Hex RG-316/U, 161, 174, 179, 187, 188 131-1403-001/016 .128 (3.25) RG-316 DS, 188 DS, 179 DS 131-1404-001/016 .151 (3.83) RG-178/U, 196 131-3302-001/006 .105 (2.67) RG-316/U, 161, 131-3303-001/006 .128 (3.25) 174, 179, 187, 188 131-3303-401/406 .128 (3.25) RG-179 DS, 187 DS,188 DS, 316 DS 131-3304-401/406 .151 (3.83) RG-178/U, 196 131-3402-001/016 .105 (2.67) RG-316/U, 161, 131-3403-001/016 .128 (3.25) 174, 179, 187, 188 131-3403-401/406 .128 (3.25) RG-179 DS, 187 DS, 131-3404-401/406 .128 (3.25) 188 DS, 316 DS 131-3404-001/016 .151 (3.83) RG-58/U, 141, 303 131-3407-001/006 .213 (5.41) RG-316/U, 161, 174, 188 131-6303-401/406 .128 (3.25) RG-316 DS, 188 DS 131-6304-401/406 .151 (3.83) RG-179/U, 187 131-6333-401/406 .128 (3.25) RG-316/U, 161, 174, 188 131-6403-001/006 .128 (3.25) RG-316 DS, 188 DS 131-6404-001/006 .151 (3.83) RG-179/U, 187 131-6433-001/006 .128 (3.25) RG-179/U, 187, 316, 161, 174, 188 131-8303-401/406 .128 (3.25) RG-179 DS, 187 DS, 188DS, 316DS 131-8304-401/406 .151 (3.83) RG-179/U, 187, 316, 131-8403-001/006 .128 (3.25) 161, 174, 188 131-8403-011/016 .128 (3.25) RG-179 DS, 187 DS, 131-8404-001/006 .151 (3.83) 188 DS, 316 DS 131-8404-011/016 .151 (3.83) RG-59 131-8409-001/006 .255 (6.48) BELDEN 735A 131-8445-001/006 .178 (4.52) 257 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
131-1403-001
物料型号:文档列出了不同型号的RG电缆和相应的Crimp Hex尺寸。
器件简介:介绍了如何识别连接器部件,包括2件式部件(除了Bulkhead),以及如何剥离电缆并准备中心导体。
引脚分配:文档中没有明确提到引脚分配,但提供了连接器的组件图。
参数特性:包括了不同电缆组的型号和对应的Crimp Hex尺寸。
功能详解:描述了如何将电缆插入连接器主体,并确保电缆介质底部与中心接触。
应用信息:文档提供了焊接和压接两种连接方法的详细步骤。
封装信息:提供了连接器的组件图,包括Crimp Sleeve Rear Access Port、Center Contact、Body Assembly等。
131-1403-001 价格&库存
很抱歉,暂时无法提供与“131-1403-001”相匹配的价格&库存,您可以联系我们找货
