135-3436-101
135-3436-101
    CINCH
135-3436-101 数据手册
MMCX Right Angle Plug for .047 (1.20) Diameter and RG-178 Size Flexible Cable with Crimp Insert 1. Identify piece parts. (3 piece parts) 2. Strip cable jacket to dimensions shown. Do not nick braid or center conductor during strip operations. 3. Slide crimp insert over braid and against jacket. Fold braid around crimp insert as shown. Strip cable dielectric to dimension shown. Tin center conductor. 4. Slide body assembly over cable and crimp insert, then seat firmly so cable dielectric butts against contact as shown. Crimp body using recommended crimp hex. Maintain forward pressure on cable while crimping. 5. Solder contact to center conductor through rear access port. Use a minimum amount of solder for a full fillet joint. 6. Press end cap into access port using .156 (3.96) diameter flat punch or Johnson assembly tool 141-0000-910. Cable Group Part No. “L” Crimp Hex .047 Flexible 135-3436-101 .140 (3.56) .105 (2.67) RG-178/U, 196 135-3402-101 .188 (4.78) .105 (2.67) .047 Flexible 135-9436-101 .140 (3.56) .105 (2.67) 220 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
135-3436-101 价格&库存
很抱歉,暂时无法提供与“135-3436-101”相匹配的价格&库存,您可以联系我们找货
  • 1+139.389381+18.11401
  • 10+118.4271510+15.38991
  • 25+111.0076225+14.42573
  • 50+105.7085050+13.73709
  • 100+100.66377100+13.08152
  • 250+94.36513250+12.26299
  • 500+89.86600500+11.67832
  • 1000+85.582461000+11.12166
库存:4
