MMCX Straight Jack for .047 Diameter and RG-178 Size Flexible Cable
1. Identify connector parts. (3 piece parts – except bulkhead
jack as shown.)
2. Strip cable jacket to dimensions shown. Do not nick braid
or center conductor during strip operations.
3. Slide crimp insert over braid and against jacket, fold braid
around crimp insert. Strip dielectric to dimension shown.
Tin center conductor if contact will be solder attached.
Do not tin center conductor if contact is to be crimp
attached.
4. Assemble contact assembly onto cable as shown.
Solder attachment: Solder contact to center conductor.
Care should be taken that excess solder is not applied.
Crimp attachment: Crimp contact to center conductor
using Johnson hand tool 140-0000-952 and die set 1400000-953. Crimp location should be centered between
end of contact and cross-hole.
Crimp attachment to solid center conductor cables is not
recommended.
5. 5. Slide body assembly over contact and crimp insert,
then seat firmly onto contact. Crimp body using
recommended crimp hex. Bulkhead jack requires 140000-951 dieset. Maintain forward pressure on cable while
crimping.
Cable Group
Part No.
“L”
Crimp Hex
.047 Flexible
135-3336-001
135-3336-401
.135 (3.43)
.135 (3.43)
.105 (2.67) x .250 (6.35) W
RG-178/U, 196
135-3302-001
135-3302-401
.185 (4.67)
.185 (4.67)
.047 Flexible
135-9436-001
.135 (3.43)
RG-178/U, 196
135-9402-001
.185 (4.67)
225
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“135-9402-001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+168.893371+21.87760
- 国内价格
- 11+115.71272
- 40+110.08132
