133-9403-101
133-9403-101
    CINCH
    MCX
133-9403-101 数据手册
MCX Crimp Type Right Angle Plugs for Flexible Cable 1. Identify connector parts. (4 piece parts). 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin (optional). Slide crimp sleeve onto cable as shown. 3. Flare braid and slide cable into body making certain that the cable dielectric bottoms against center contact. Solder: Solder center conductor to contact through the side access ports and hole in center contact. Use a minimum amount of solder for a full fillet joint. .015 (0.38) diameter solder is recommended. Crimp: Crimp Contact Attachment Crimp contact using 41-0000-924 dieset in 144-0000-900 tool frame. 4. Arrange braid uniformly around crimp stem. Slide crimp sleeve over braid and access ports. Crimp securely using recommended hex size and crimp tool. Cable Group Part No. Sleeve Hex RG-316/U, 188, 174 133-9403-101/104 .128 (3.25) RG-316 DS, 188 DS 133-9404-101 .151 (3.83) RG-178 133-9402-101 .105 (2.67) 228 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
133-9403-101 价格&库存
很抱歉,暂时无法提供与“133-9403-101”相匹配的价格&库存,您可以联系我们找货
