142-4403-101
142-4403-101
    CINCH
    RP-SMA
142-4403-101 数据手册
SMA Crimp Type Right Angle Plugs for Flexible Cable 1. Identify connector parts. (3 piece parts) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. When stripping LMR-100 low loss cable, remove foil back to where cable jacket is stripped. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin (optional). Slide crimp sleeve onto cable as shown. 3. Flare braid and slide cable into body making certain that the cable insulation bottoms on center contact. Solder center conductor to contact through the rear access port. Use a minimum amount of solder for a full fillet joint. .020 (0.51) diameter solder is recommended. 4. Arrange braid uniformly around crimp stem. Slide crimp sleeve over braid and crimp securely using recommended crimp tool. Place expansion cap in access port and seat with .187 (4.75) diameter flat punch. Shrink heat shrink tubing over crimp sleeve if applicable. 243 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17 SMA Crimp Type Right Angle Plugs for Flexible Cable (cont’d from last page) Cable Group Part No. Crimp Hex 141-0403-102 .128 (3.25) RG-316 DS, 188 DS 141-0404-112 .151 (3.83) RG-58/U, 141, 303 141-0407-102 .213 (5.41) RG-55/U, 142, 223, 400 141-0408-102 .213 (5.41) RG-178/U, 196 142-0402-101 142-0402-106 .105 (2.67) .105 (2.67) RG-316/U, 161, 174, 188; LMR-100 142-0403-101 142-0403-106 .128 (3.25) .128 (3.25) RG-316 DS, 188 DS 142-0404-101 142-0404-106 .151 (3.83) .151 (3.83) RG-58/U, 141, 303 142-0407-101 142-0407-106 .213 (5.41) .213 (5.41) RG-55/U, 142, 223, 400 142-0408-101 142-0408-106 .213 (5.41) .213 (5.41) RG-179/U, 187 142-0433-101 142-0433-106 .128 (3.25) .128 (3.25) RG-316/U, 161, 174, 188; LMR-100 142-4403-101 142-4403-106 .128 (3.25) .128 (3.25) RG-316 DS, 188 DS 142-4404-101 142-4404-106 .151 (3.83) .151 (3.83) RG-58/U, 141, 303 142-4407-101 142-4407-106 .213 (5.41) .213 (5.41) RG-55/U, 142, 223, 400 142-4408-101 142-4408-106 .213 (5.41) .213 (5.41) RG-316/U, 161, 174, 188; LMR-100 142-5403-101 142-5403-106 .128 (3.25) .128 (3.25) RG-316 DS, 188 DS 142-5404-101 142-5404-106 .151 (3.83) .151 (3.83) RG-58/U, 141, 303 142-5407-101 142-5407-106 .213 (5.41) .213 (5.41) RG-55/U, 142, 223, 400 142-5408-101 142-5408-106 .213 (5.41) .213 (5.41) RG-316/U, 188, 174 142-9403-101 .128 (3.25) RG-316 DS, 188 DS 142-9404-101 .151 (3.83) RG-58/U, 141 142-9407-101 .213 (5.41) RG-316/U, 161, 174, 188; LMR-100 244 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-4403-101 价格&库存
很抱歉,暂时无法提供与“142-4403-101”相匹配的价格&库存,您可以联系我们找货
