EPB.00.250.NTN
EPB.00.250.NTN
    LEMO(雷莫)
    插件
    EPB.00.250.NTN
EPB.00.250.NTN 数据手册
EPB.00.250.NTN www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Female print PCB IP rating 50 AWG wire size 0.00 - 0.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Matching parts FFA.00.250.NTAC29 Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model EPB*: Straight receptacle for printed circuit Keying Circular, female Housing Material Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces Weight 2.65 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Printed Circuit Board) Contact Dia.: 0.7 mm (0.028in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >144 hr DRAWINGS Dimensions A L mm. 7 12 in. 0,28 0,47 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.00.M07.4 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
EPB.00.250.NTN
物料型号为LEMO EPB.00.250.NTN,是一种用于印刷电路板的直式插座,具有圆形、女性化的键控设计。
器件简介包括其为1个同轴(50欧姆)配置,额定电流为4安培,绝缘体材料为PTFE。
引脚分配为1个同轴接触,接触直径为0.7毫米,测试电压为2.1千伏(rms)。
参数特性包括最大电阻6.1毫欧姆,电压测试为2100伏(交流)和3000伏(直流),阻抗为50欧姆,电压驻波比为1.09加上0.11乘以频率除以吉赫。
功能详解包括5000次的外壳耐久性,最小保持力100牛顿,以及超过144小时的盐雾腐蚀测试。
应用信息未在文档中明确说明,但根据其特性,可能适用于需要高电流和高电压的同轴连接。
封装信息包括尺寸为7毫米(长)x 12毫米(宽),重量为2.65克,材料为黄铜(镀镍),并推荐使用特定的扳手和扭矩扳手进行操作。
EPB.00.250.NTN 价格&库存
很抱歉,暂时无法提供与“EPB.00.250.NTN”相匹配的价格&库存,您可以联系我们找货
