145-0693-002
145-0693-002
    CINCH
145-0693-002 数据手册
SMK Solder Type Straight Plugs for Semi-Rigid Cable 1. Identify connector parts (5 piece parts) and tools (5 tools.) 2. Strip cable jacket and dielectric to dimension shown. 3. Place center contact onto center conductor. Slide contact soldering tool onto contact. Clamp the cable contact and tool into cable soldering vise and solder contact to center conductor. High temperature solder, such as 95/5 Sn/Ag is recommended so that contact solder joint remains stable during body soldering operation. Solder paste is recommended for the contact solder joint to minimize excess solder. The assembled contact dimension should be as shown. 4. Remove excess solder from contact with a sharp blade and clean contact. Check for presence of excess solder by sliding body soldering tool over the contact. Remove soldering tool. 5. Place connector nut and body on cable. Place connector body soldering tool over contact and thread the coupling nut and connector body firmly to the tool. Place cable subassembly into cable soldering vise. Clamp cable and soldering tool securely to insure the cable dielectric expansion will not disturb the cable in the vise during soldering. Place hot soldering iron on the connector body sleeve and apply solder from the opposite side. A low temp solder, such as 60/40 Sn/Pb is recommended for the body solder joint. Allow the soldered joint to cool and remove from fixture. Check contact location to the body. The best electrical results are achieved when the contact location is within a tolerance of .060 +/- .001. 6. Place bead onto neck portion of the tool. Thread Bead Assembly tool firmly into the coupling nut. Push the tool’s plunger between your thumb and fingers to assemble the bead. Check bead location. Assemble seal ring onto body. 145-0693-001/002 (for .086 Semi-Rigid) 145-0694-001/02 (for .141 Semi-Rigid) Semi-Rigid Cable Vise 140-0000-962 140-0000-962 Vise Stop 140-0000-968 140-0000-968 Bead Assy. Tool 140-0000-957 140-0000-957 Contact Soldering Tool 140-0000-960 140-0000-961 Body Soldering Tool 140-0000-958 140-0000-959 Cable Clamp Insert 140-0000-964 140-0000-965 Tool 232 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
145-0693-002 价格&库存
很抱歉,暂时无法提供与“145-0693-002”相匹配的价格&库存,您可以联系我们找货
