SMA Right Angle Solder Type Plug for Semi-Rigid Cable
1. Identify connector parts. (2 piece parts)
2. Strip cable to dimensions shown. Do not nick center conductor. Bevel the cable
center conductor per contact detail of SMA interface on page 48. Slide coupling
nut onto cable as shown.
Cable Group
Part No.
RG-402/U (.141
Semi-Rigid)
142-0694-021
142-0694-026
142-0694-041
142-0694-046
3. Insert cable into body making sure cable jacket is bottomed against shoulder
inside of body. Solder body to cable. Use a minimum amount of heat to
minimize cable insulation movement. Trim expanded insulation flush with front of
body or fixture body and cable during soldering to prevent insulation expansion.
4. Thread coupling nut over body.
SMA Solder Type Straight Plugs for Semi-Rigid Cable
1. Identify connector parts. (3 piece parts)
2. Strip cable to dimensions shown. Do not nick center conductor. Bevel the cable center
Cable Group
Part No.
RG-402/U (.141
Semi-Rigid)
142-0694-031
142-0694-036
3. 3. Insert cable into body making sure cable jacket is flush with front of body. Solder
body to cable. Use a minimum amount of heat to minimize cable insulation movement.
Trim expanded cable insulation flush with front of body or fixture body and cable during
4. Snap “C” spring onto connector body groove. Compress “C” spring using 141-0000904 compression tool. Install coupling nut onto connector body. Nut should spin freely.
235
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“142-0694-021”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+104.415521+13.52547
