Description
Body
Socket
Insulation
Crimp Ring
Heat Shrink
Material
Brass
BE CU
PTFE
Brass
Polyolefin
Finish
Gold
Gold
N/A
Gold
Black
REVISIONS
REV
DESCRIPTION
DATE
APPV
B
C
Added new title block and heat shrink; updated instructions
11-JUL-12
SAH
Updated Assembly Instruction 4 and Note 3
2-NOV-17
CLL
CRIMP RING
SOCKET
SIDE VIEW
PIN CHUCK
Ø0.154
[3.90]
0.2x2x2 GROOVE
Ø0.173
[4.40]
Ø0.138
[3.50]
Ø0.102
[2.60]
Ø0.028
[0.70]
0.200
[5.10]
Ø0.039
[1.00]
0.197
[5.00]
0.276
[7.00]
HEAT SHRINK
0.335
[8.50]
Ø0.197
[5.00]
0.476
[12.10]
0.787
[20.00]
CONMMCX011 ASSEMBLY INSTRUCTIONS
1.
2.
3.
4.
5.
6.
Strip cable to recommended dimensions.
Slip heat shrink and crimp ring onto stripped cable.
Solder the socket to the center conductor.
Insert the socket and center conductor into the body
until the socket snaps in.
Wrap the braid around the tail of the body and crimp the ring with a
0.128” hex crimp tool (or one labeled for use with RG-174 cable).
Use heat shrink to cover crimp.
RECOMMENDED CABLE STRIPPING DIMENSIONS
0.083 0.047
[2.10] [1.20]
0.228
[5.80]
RG-174 Cable
NOTES: (UNLESS OTHERWISE SPECIFIED)
1. ALL DIMENSIONS ARE IN INCHES [mm].
2. DIMENSIONS APPLY AFTER FINISHING.
3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE, USE
MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY
HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE
SOURCED MATERIALS.
4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM.
: THIS DRAWING CONTAINS PROPRIETARY INFORMATION
THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE
TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS
DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE
EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS
DESIGNATED AGENTS.
MATERIAL:
FINISH:
PROJECTION:
TOLERANCES:
.020 [0.50]-.200 [5.00]= .008 [0.20]
.200 [5.00]-1.200 [30.00]= .016 [0.40]
1.20 [30.0]-4.75 [120.0]= .024 [0.60]
4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1
159 ORT LANE
MERLIN, OR 97532
TITLE:
MMCX FEMALE CABLE END CRIMP
FOR RG174 CABLE
SIZE DWG. NO.
DRAWN: B.MURPHY DT: 11-JUL-12
ENGR: S.HOGAN
DT: 11-JUL-12 SCALE: 2:1
REV
CONMMCX011
DO NOT SCALE DRAWING
C
SHEET 1 OF 1
LDCFDLT_A
很抱歉,暂时无法提供与“CONMMCX011”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+154.24162
- 4+103.11180
- 8+74.39389
