CONREVSMA014-R178
CONREVSMA014-R178
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA Connector Receptacle, Male Pin 50 Ohm Panel Mount, Bulkhead - Front Side Nut Solder
CONREVSMA014-R178 数据手册
Description Body Pin Insulation O Ring Washer Nut Spacer Support Heat Shrink Material Brass BE CU PTFE Si Rubber Brass Brass PTFE Brass Polyolefin Finish Nickel Gold N/A Rubber Nickel Nickel N/A Nickel Black REVISIONS RECOMMENDED MOUNTING HOLE REV Ø0.256 (6.50) Add heat shrink, new frame, revised stripping instruct./dims B Added new title block; update material PIN Ø0.020 (0.50) 0.236 (6.00) 0.500 (12.70) FLAT 0.228 (5.80) DATE A SIDE VIEW 1/4"-36UNS-2A THREADS DESCRIPTION 4/26/10 CJ 11-JUL-12 BPM SUPPORT SPACER Ø0.049 (1.24) HEAT SHRINK Ø0.118 (3.00) H0.433 (11.00) Ø0.102 (2.60) Ø0.236 (6.00) 0.787 (20.00) BACK VIEW WASHER 0.197 (5.00) 0.417 (10.60) 0.083 (2.10) CONREVSMA014-R178 ASSEMBLY INSTRUCTIONS 1. Strip the cable to the recommended dimensions. 2. Slide the coax into the support until the outside insulation bottoms out against the inside shoulder of the support. 3. Solder the support onto the braid. 4. Place the spacer onto the center conductor. 5. Solder or crimp the pin onto the center conductor. 6. Insert the pin, center conductor, spacer, and support into the body until the top of the pin is flush to end of the body. 7. Crimp the tail of the body onto the support with a 0.093” hex crimp tool. RECOMMENDED CABLE STRIPPING DIMENSIONS 0.217 0.032 (5.50) (0.80) 0.197 (5.00) Ø0.402 (10.20) 0.433 (11.00) 0.748 (19.00) NUT H0.315 (8.00) FLAT 0.228 (5.80) 0.248 (6.30) APPV 1/4-36UNS-2B THREADS 0.020 (0.50) 0.065 (1.65) NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: RG-178 Cable FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 DRAWN: CJ ENGR: DT: 4/26/10 DT: MERLIN, OR 97532 TITLE: RP-SMA FEMALE BULKHEAD MOUNT CABLE END CRIMP WITH O-RING FOR RG178 CABLE SIZE DWG. NO. CONREVSMA014-R178 SCALE: 2:1 DO NOT SCALE DRAWING REV B SHEET 1 OF 1 LDCFDLT_A
CONREVSMA014-R178 价格&库存
很抱歉,暂时无法提供与“CONREVSMA014-R178”相匹配的价格&库存,您可以联系我们找货
