PCB.SMAFST.J.B.HT
PCB.SMAFST.J.B.HT
    TAOGLASLIMITED
    SMA
PCB.SMAFST.J.B.HT 数据手册
SPECIFICATION Part No. : PCB.SMAFSTJ.B.HT Product Name : SMA (F) Surface Mount PCB Jack Feature : SMA(F) Jack Surface Mount PCB Jack Frequency Range: 0~12.4GHz Finish: Gold Leg Length: 1mm Total Length: 10.40mm RoHS Compliant SPE-12-8-143/A/WY Page 1 of 3 1. Introduction The PCB.SMAFSTJ.B.HT connector was designed to be surface mounted on a PCB, it has a Solder Post for connection. The connector pin is directly soldered onto pads on the PCB. The connector is a standard SMA (F) Jack. The SMA connector is the most popular type connector for RF applications. Taoglas connectors are all RoHS compliant. 2. Specification ELECTRICAL Impedance 50Ω Frequency Range 0~12.4 GHz Working Voltage Max. 335 Vrms Dielectric withstanding Voltage ≤1000 Vrms Insulation Resistance ≥5000M Ω MECHANICAL Connector Dimension 10.4 X 5.35 mm Connector Pin Diameter 1.27 mm Max. Thickness PCB acceptable 0.8 mm Connector Type SMA (F) ENVIRONMENTAL RoHS compliant SPE-12-8-143/A/WY Page 2 of 3 3. Connector Drawing Name Material Finish QTY 1 Body Brass Gold 1 2 Female Contact Phosphor Bronze Gold 1 3 Insulator Teflon White 1 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © 2012, Taoglas Ltd. SPE-12-8-143/A/WY Page 3 of 3
PCB.SMAFST.J.B.HT 价格&库存
很抱歉,暂时无法提供与“PCB.SMAFST.J.B.HT”相匹配的价格&库存,您可以联系我们找货
PCB.SMAFSTJ.B.HT
  • 1+44.115711+5.71453
  • 10+37.5138310+4.85936
  • 25+35.1636925+4.55493
  • 50+33.4839950+4.33735
  • 100+31.88526100+4.13026
  • 250+29.88922250+3.87170
  • 500+28.46312500+3.68697
  • 1000+27.105571000+3.51112
  • 2500+25.410282500+3.29152
PCB.SMAFSTJ.B.HT
    • 1+57.16440
    • 200+22.80960
    • 500+22.05360
    • 1000+21.67560
    PCB.SMAFST.J.B.HT
    • 1+31.607841+4.09432
    PCB.SMAFST.J.B.HT
      • 1+39.99240
      • 200+15.96240
      • 500+15.43320
      • 1000+15.16320
