CONSMA005-R178
CONSMA005-R178
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    SMA
CONSMA005-R178 数据手册
Description Body Socket Pin Insulator Washer Nut Spacer Shield Sleeve Retaining Nut Crimp Ring Heat Shrink Material Brass BE CU PTFE Brass Brass PTFE Brass Brass Brass Polyolefin Finish Nickel Gold N/A Nickel Nickel N/A Nickel Nickel Nickel Black REVISIONS 0.189 [4.80] 0.213 [5.40] 0.197 [5.00] REV RG-178 Cable B DESCRIPTION Updated footprint and dimensions; Added new title block 0.446 [11.40] 0.020 [0.50] 0.636 [16.30] Ø0.254 [6.50] SOCKET 0.234 [6.00] 0.118 [3.00] 0.917 [23.30] RETAINING NUT SPACER STRIPPED CABLE SHRINK WRAP NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. 2. DIMENSIONS APPLY AFTER FINISHING. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE CONSMA005 ASSEMBLY INSTRUCTIONS Strip cable to recommended dimensions. Slip heat shrink and crimp ring onto stripped cable. Insert the stripped cable through the retaining nut, shield sleeve, and spacer. Solder the socket to the center conductor. Insert the socket into the pin insulator, then screw the main body onto the retaining nut. Wrap the braid around the tail of the body and crimp the ring with a 0.100" hex crimp tool (or one labeled for use with RG-178 cable). Use heat shrink to cover crimp. Use the nut and washer to secure the connector to a case. SPACER CRIMP RING SHIELD SLEEVE MAIN BODY RECOMMENDED MOUNTING HOLE 0.059 (1.50) SOCKET 7. 8. 0.354 [9.00] Ø0.179 [4.55] WASHER PIN INSULATOR 6. Ø0.049 [1.24] 0.094 [2.40] 0.010 [5.00] WASHER 4. 5. HEAT SHRINK Ø0.079 [2.00] SIDE VIEW 1. 2. 3. Ø0.118 [3.00] CRIMP RING NUT NUT BPM Ø0.126 [3.20] H0.315 [8.00] 0.065 [1.65] 29-JUN-12 1/4-36UNS-2A THREADS Ø0.402 [10.20] 1/4-36UNS-2B THREADS APPV 0.787 [20.00] 0.236 [6.00] RECOMMENDED CABLE STRIPPING DIMENSIONS DATE THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: MERLIN, OR 97532 SMA FEMALE BULKHEAD MOUNT CABLE END CRIMP FOR RG178 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 29-JUN-12 SCALE: 2:1 ENGR: DT: REV CONSMA005-R178 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONSMA005-R178 价格&库存
很抱歉,暂时无法提供与“CONSMA005-R178”相匹配的价格&库存,您可以联系我们找货
