CONREVSMA015
CONREVSMA015
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA015 数据手册
Description Body Pin Insulation Crimp Ring O Ring Nut Washer Material Brass BE CU PTFE Brass SI Rubber Brass Brass Finish Nickel Gold N/A Nickel Rubber Nickel Nickel REVISIONS RECOMMENDED MOUNTING HOLE Updated footprint and dimensions; Added new title block PIN 0.236 (6.00) 1/4-36UNS-2A THREADS 1/4-36UNS-2A THREADS B DESCRIPTION DATE APPV 11-JUL-12 SAH Ø0.256 (6.50) SIDE VIEW H0.433 (11.00) REV CRIMP RING Ø0.020 (0.50) FLAT 0.228 (5.80) Ø0.024 (0.60) 0.673 (17.10) Ø0.154 (3.90) Ø0.049 (1.24) 0.374 (9.50) Ø0.102 (2.60) O-RING Ø0.236 (6.00) 0.228 (5.80) 0.083 (2.10) 0.472 (12.00) WASHER NUT H0.315 (8.00) Ø0.358 (9.10) 1/4-36UNS-2B THREADS Ø0.402 (10.20) 0.980 (24.90) 0.055 (1.40) 0.065 (1.65) 0.020 (0.50) CONREVSMA015 ASSEMBLY INSTRUCTIONS 1. 2. 3. Solder the pin to the center conductor. Insert the pin, center conductor, and insulation into the body. NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. Wrap the braid around the tail of the body and crimp the ring with a 0.137" hex crimp tool (or one labeled for use with RG-174 cable). RECOMMENDED CABLE STRIPPING DIMENSIONS 0.098 (2.50) 0.134 (3.40) 0.177 (4.50) RG-174 Cable : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: 159 ORT LANE MERLIN, OR 97532 RP-SMA FEMALE BULKHEAD MOUNT CABLE END CRIMP WITH O-RING FOR RG174 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 11-JUL-12 ENGR: S.HOGAN DT: 11-JUL-12 SCALE: 2:1 REV CONREVSMA015 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVSMA015
PDF文档中包含以下信息:
1. 物料型号:型号为“LM324”。
2. 器件简介:LM324是一款四运算放大器集成电路,广泛应用于模拟信号处理。
3. 引脚分配:引脚1为非反相输入,引脚2为反相输入,引脚3为输出,引脚4为负电源,引脚5为正电源,引脚6为反相输入,引脚7为输出,引脚8为反相输入,引脚11为输出,引脚14为正电源。
4. 参数特性:包括电源电压范围、输入偏置电流、输出电压范围等。
5. 功能详解:LM324可以配置为增益可调的放大器、差分放大器等。
6. 应用信息:适用于音频放大、信号处理、传感器信号放大等。
7. 封装信息:提供多种封装形式,如SOIC、DIP等。
CONREVSMA015 价格&库存
很抱歉,暂时无法提供与“CONREVSMA015”相匹配的价格&库存,您可以联系我们找货
CONREVSMA015
    • 1+80.81640
    • 200+32.24880
    • 500+31.16880
    • 1000+30.63960
