SPECIFICATION
Part No.
PCB.SMAFSTJ.A.HT
Product Name
SMA (F) Through Hole PCB Mount Jack
Feature
SMA(F) Jack
Through Hole PCB Jack
Frequency Range: 0~12.4GHz
Finish: Gold
Leg Length: 2mm
Total Length: 11.00mm
RoHS Compliant
SPE-12-8-142/B/WY
Page 1 of 3
1. Introduction
The PCB.SMAFSTJ.A.HT connector was designed to be mounted on a PCB, it has a Solder Post for
connection. The connector pin is directly soldered onto pads on the PCB. The connector is a
standard SMA (F) Jack. The SMA connector is the most popular type connector for RF
applications. Taoglas connectors are all RoHS compliant.
2. Specification
ELECTRICAL
Impedance
50Ω
Frequency Range
0~12.4 GHz
Working Voltage
Max. 335 Vrms
Dielectric withstanding Voltage
≤1000 Vrms
Insulation Resistance
≥5000M Ω
MECHANICAL
Connector Dimension
11 X 7 mm
Connector Pin Diameter
1.27 mm
Max. Thickness PCB acceptable
0.8 mm
Connector Type
SMA (F)
ENVIRONMENTAL
RoHS compliant
SPE-12-8-142/B/WY
Page 2 of 3
3. Connector Drawing
Name
Material
Finish
QTY
1
Body
Brass
Gold
1
2
Insulator
Teflon
White
1
3
Female Contact
Phosphor Bronze
Gold
1
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties
without express permission is strictly prohibited. Copyright © 2012, Taoglas Ltd.
SPE-12-8-142/B/WY
Page 3 of 3
很抱歉,暂时无法提供与“PCB.SMAFST.J.A.HT”相匹配的价格&库存,您可以联系我们找货
