133-3404-101
133-3404-101
    CINCH
    MCX
133-3404-101 数据手册
MCX Crimp Type Right Angle Plugs for Flexible Cable – 50 Ohm 1. Identify connector parts. (4 piece parts except RG-58) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin (optional). Slide crimp sleeve onto cable shown. 3. Flair braid and slide cable into body making certain that the cable insulation bottoms on center contact. Arrange braid uniformly around crimp stem. Slide crimp sleeve over braid and crimp securely using recommended crimp tool. 4. Solder center conductor to contact through rear access port. Use a minimum amount of solder for a full fillet joint. .020 (0.51) diameter solder is recommended. 5. Assemble insulator, if applicable; then place expansion cap in access port and seat with .156 (3.96) diameter flat punch or MCX hand assembly tool 141-0000-908. Shrink heat shrink tubing over crimp sleeve if applicable. Cable Group Part No. “A” “B” “C” Crimp Hex RG-178/U, 196 133-3402-101/106 .050 (1.27) .270 (6.86) .200 (5.08) .105 (2.67) RG-188/U, 316, 161, 174 133-3403-101/106 .050 (1.27) .270 (6.86) .200 (5.08) .128 (3.25) RG-316 DS, 188 DS 133-3404-101/106 .050 (1.27) .270 (6.86) .200 (5.08) .151 (3.83) RG-179/U, 187 133-3433-101/106 .050 (1.27) .270 (6.86) .200 (5.08) .128 (3.25) RG-178/U, 196 133-5402-101/106 .050 (1.27) .270 (6.86) .200 (5.08) .105 (2.67) RG-188/U, 316, 161, 174 133-5403-101/106 .050 (1.27) .270 (6.86) .200 (5.08) .128 (3.25) RG-316 DS, 188 DS 133-5404-101/106 .050 (1.27) .270 (6.86) .200 (5.08) .151 (3.83) RG-58/U, 303, 141 133-3407-101/106 .067 (1.70) .295 (7.49) .210 (5.33) .213 (5.41) 230 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
133-3404-101 价格&库存
很抱歉,暂时无法提供与“133-3404-101”相匹配的价格&库存,您可以联系我们找货
