135-3404-101
135-3404-101
    CINCH
135-3404-101 数据手册
MMCX Right Angle Plug for RG-178, RG-316, RG-316 DS and RG-179 Size Flexible Cable 1. Identify connector parts. (3 piece parts) 2. Strip cable jacket to dimensions shown. Do not nick braid or center conductor during strip operations. Tin center conductor. Slide crimp sleeve onto cable jacket. 3. Flair braid and assemble crimp stem of body subassembly under braid onto cable making certain that the cable center conductor enters contact slot as shown. Arrange braid uniformly around crimp stem. Slide crimp sleeve over braid and crimp securely using recommended crimp hex. 4. Solder center conductor to contact through rear access prot. Use a minimum amount of solder for a full fillet joint. 5. Press end cap into body access port using . 156 (3.96) diameter flat punch or Johnson assembly tool 141-000-910. Cable Group Part No. Crimp Hex “A” “B” “C” RG-178, 196 135-3402-111 .105 (2.67) .310 .100 .035 RG-316/U, 188, 187, 179 135-3403-101 .128 (3.25) .295 .105 .075 RG-316 DS, 188 DS 135-3404-101 .151 (3.83) .295 .105 .075 221 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
135-3404-101 价格&库存
很抱歉,暂时无法提供与“135-3404-101”相匹配的价格&库存,您可以联系我们找货
  • 1+88.137491+11.45369
  • 10+74.8593110+9.72816
  • 25+70.1672425+9.11842
  • 50+66.8167450+8.68301
  • 100+63.62717100+8.26852
  • 250+59.64514250+7.75104
  • 500+56.80076500+7.38141
  • 1000+54.092731000+7.02949
库存:533
135-3404-101
  • 30+37.17984
  • 65+36.51483
  • 100+34.44727
  • 500+30.39678
  • 1000+23.72255
库存:1191
