135-3336-001
    CINCH
    MMCX Connector Jack, Female Socket 50 Ohm Free Hanging (In-Line) Crimp or Solder
135-3336-001 数据手册
MMCX Straight Jack for .047 Diameter and RG-178 Size Flexible Cable 1. Identify connector parts. (3 piece parts – except bulkhead jack as shown.) 2. Strip cable jacket to dimensions shown. Do not nick braid or center conductor during strip operations. 3. Slide crimp insert over braid and against jacket, fold braid around crimp insert. Strip dielectric to dimension shown. Tin center conductor if contact will be solder attached. Do not tin center conductor if contact is to be crimp attached. 4. Assemble contact assembly onto cable as shown. Solder attachment: Solder contact to center conductor. Care should be taken that excess solder is not applied. Crimp attachment: Crimp contact to center conductor using Johnson hand tool 140-0000-952 and die set 1400000-953. Crimp location should be centered between end of contact and cross-hole. Crimp attachment to solid center conductor cables is not recommended. 5. 5. Slide body assembly over contact and crimp insert, then seat firmly onto contact. Crimp body using recommended crimp hex. Bulkhead jack requires 140000-951 dieset. Maintain forward pressure on cable while crimping. Cable Group Part No. “L” Crimp Hex .047 Flexible 135-3336-001 135-3336-401 .135 (3.43) .135 (3.43) .105 (2.67) x .250 (6.35) W .105 (2.67) x .250 (6.35) W RG-178/U, 196 135-3302-001 135-3302-401 .185 (4.67) .185 (4.67) .105 (2.67) x .250 (6.35) W .047 Flexible 135-9436-001 .135 (3.43) .105 (2.67) x .250 (6.35) W .105 (2.67) x .250 (6.35) W RG-178/U, 196 135-9402-001 .185 (4.67) .105 (2.67) x .250 (6.35) W 225 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
135-3336-001 价格&库存
很抱歉,暂时无法提供与“135-3336-001”相匹配的价格&库存,您可以联系我们找货
