135-3402-001
135-3402-001
    CINCH
135-3402-001 数据手册
MMCX Straight Plug for .047 (1.19) Diameter and RG-178 Size Flexible Cablev 1. Identify piece parts. (3 piece parts) 2. Strip cable jacket to dimensions shown. Do not nick braid or center conductor during strip operations. 3. Slide crimp insert over braid and against jacket. Fold braid around crimp insert as shown. Strip dielectric to dimension shown. Tin center conductor if contact is to be soldered attached. Do not tin center conductor if contact is to be crimp attached. 4. Assemble contact assembly onto cable as shown. Solder attachment: Solder contact to center conductor. Care should be taken that excess solder is not applied. Crimp attachment: Crimp contact to center conductor using Johnson hand tool 140-0000-952 and die set 140000-953. Crimp location should be centered between and of contact and cross-hole. Crimp attachment to solid center conductor cables is not recommended. 5. Slide body assembly over contact and crimp insert, then seat firmly as shown. Crimp body using recommended crimp die hex. Maintain forward pressure on cable while crimping. Cable Group Part No. Strip Length Crimp Hex .047 Flexible 135-3436-001 .135 (3.43) .105 (2.67) x .250 (6.35) W RG-178/U, 196 135-3402-001 .184 (4.67) .105 (2.67) x .250 (6.35) W 222 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
135-3402-001 价格&库存
很抱歉,暂时无法提供与“135-3402-001”相匹配的价格&库存,您可以联系我们找货
  • 25+70.3661325+9.11528
  • 50+49.7016850+6.43839
  • 100+46.07687100+5.96883
  • 250+42.34507250+5.48541
库存:275
135-3402-001
  • 1+57.534671+7.45309
