131-8403-101
131-8403-101
    CINCH
    SMB
131-8403-101 数据手册
SMB/SMC/Mini-75Ohm SMB Crimp Type Right Angle Plugs and Right Angle Bulkhead Jacks for Flexible Cable 1. Identify connector parts. (4 piece parts: crimp sleeve, body assembly, expansion cap and covering ring. Die cast body only.) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin (optional). Slide crimp sleeve onto cable as shown. 3. Flare braid and slide cable into body assembly making certain that the cable insulation bottoms on center contact. Arrange braid uniformly around crimp stem of body assembly. Slide crimp sleeve over braid and crimp securely using recommended crimp tool. 4. Solder center conductor to contact through the rear and side access ports. Use a minimum amount of solder for a good joint. .020 (0.51) diameter solder is recommended. Place expansion cap in access port and seat with a .125 (3.17) diameter flat punch. Snap cover ring over side access port if applicable. Cable Group Part No. “A” “B” Crimp Hex RG-178/U, 196 131-1402-101/116 .219 (5.56) .312 (7.92) .105 (2.67) RG-316/U, 161, 174, 179, 187, 188 131-1403-101/116 .219 (5.56) .312 (7.92) .128 (3.25) RG-179 DS, 187 DS,188DS, 316 DS 131-1404-101/116 .219 (5.56) .312 (7.92) .151 (3.83) RG-316/U, 161, 174,179, 187, 188 131-3303-501/506 .219 (5.56) .312 (7.92) .128 (3.25) RG-179 DS, 187 DS,188 DS, 316 DS 131-3304-501/506 .219 (5.56) .312 (7.92) .151 (3.83) RG-178/U, 196 131-3402-101/116 .177 (4.50) .289 (7.34) .105 (2.67) RG-316/U, 161, 174,179, 187, 188 131-3403-101/116 .177 (4.50) .289 (7.34) .128 (3.25) RG-179 DS, 187 DS,188 DS, 316 DS 131-3404-101/116 .177 (4.50) .289 (7.34) .151 (3.83) RG-58/U, 141, 303 131-3407-101/106 .219 (5.56) .289 (7.34) .213 (5.41) RG-316/U, 161, 174, 188 131-6403-101/106 .219 (5.56) .312 (7.92) .128 (3.25) 316 DS, 188 DS 131-6404-101/106 .219 (5.56) .312 (7.92) .151 (3.83) RG-179/U, 187 131-6433-101/106 .219 (5.56) .312 (7.92) .151 (3.83) RG-179/U, 187, 316, 131-8403-101/106 .177 (4.50) .289 (7.34) .128 (3.25) 161, 174, 188 131-8403-111/116 .219 (5.56) .312 (7.92) .128 (3.25) RG-179 DS, 187 DS 131-8404-101/106 .177 (4.50) .289 (7.34) .151 (3.83) 316 DS, 188 DS 131-8404-111/116 .219 (5.56) .312 (7.92) .151 (3.83) RG-59 131-8409-101/106 .219 (5.56) .289 (7.34) .255 (6.48) BELDEN 735A 131-8445-101/106 .177 (4.50) .289 (7.34) .178 (4.52) RG-316/U, 188, 174, 179, 187 131-9403-101/116 .177 (4.50) .289 (7.34) .128 (3.25) RG-316 DS, 188 DS, 179 DS, 187 DS 131-9404-101/116 .177 (4.50) 2.89 (7.34) .151 (3.83) 258 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
131-8403-101
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:适用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4mm x 4mm。
131-8403-101 价格&库存
很抱歉,暂时无法提供与“131-8403-101”相匹配的价格&库存,您可以联系我们找货
