SMA Clamp Type Right Angle Plugs for Flexible Cable
1. Identify connector parts. (4 piece parts)
2. Strip cable to dimensions shown. Do not nick braid
or center conductor. A wire stripper of correct size
is recommended for this step. Twist stranded center
conductor into tight bundle and tin (optional). Slide clamp
nut and clamp cone onto cable as shown. Clamp cone
must be oriented as shown for each size of cable. The RG58/142 clamp cone slides over braid and against jacket.
3. Flare braid and slide cable into body making certain that the
cable insulation bottoms on center contact. Stepped down
diameter of stem must slide under braid and jacket. Arrange
braid uniformly around crimp stem. Slide clamp nut against
clamp cone and braid and tighten to 10 in.-lb. torque.
4. Solder center conductor to contact through the rear access
port. Use a minimum amount of solder for a full fillet
joint. .020 (0.51) diameter solder is recommended. Place
expansion cap in access port and seat with .187 (4.75)
diameter flat punch.
Cable Group
Part No.
“A”
“B”
“C”
RG-178/U, 196
142-0202-101
142-0202-106
.280 (7.11)
.280 (7.11)
.053 (1.35)
.053 (1.35)
.085 (2.16)
.085 (2.16)
RG-316/U, 161, 174, 188
142-0203-101
142-0203-106
.280 (7.11)
.280 (7.11)
.053 (1.35)
.053 (1.35)
.085 (2.16)
.085 (2.16)
RG-58/U 141, 303
142-0207-101
142-0207-106
.395 (10.03)
.395 (10.03)
.160 (4.06)
.160 (4.06)
NONE
NONE
RG-55/U, 142, 233, 400
142-0207-101
142-0207-106
.420 (10.67)
.420 (10.67)
.180 (4.57)
.180 (4.57)
NONE
NONE
251
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“142-0207-106”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+224.477431+29.12576
- 10+190.7967610+24.75573
- 25+178.8464225+23.20518
- 50+170.3115350+22.09778
- 100+162.18795100+21.04376
- 250+152.04303250+19.72746
- 500+144.79613500+18.78718
