SMA Clamp Type Straight Plugs, Straight Jacks, and
Straight Bulkhead Jacks for Flexible Cable
1. Identify connector parts. (6 piece parts – except bulkhead)
2. Strip cable to dimensions shown. Do not nick braid
or center conductor. A wire stripper of correct size
is recommended for this step. Twist stranded center
conductor into tight bundle and tin (optional). Slide clamp
nut and clamp cone onto cable as shown. Clamp cone
must be oriented as shown for each size of cable. The RG58/142 clamp cone slides over braid and against jacket.
3. Flare braid and slide cable into clamp stem. Place rear
insulator and center contact over center conductor and
position as shown for different cable sizes. Solder center
conductor to contact through the solder hole. Solder must
not be allowed to gather and run on outside of contact.
Use a minimum amount of solder for a good joint. .020
(0.51) diameter solder is recommended.
4. Arrange braid uniformly around clamp stem. Slide center
contact assembly into body. Slide clamp nut against
clamp cone and braid and tighten to 10 in.-lb. torque.
Cable Group
Part No.
“A”
“B”
“C”
RG-178/U, 196
142-0202-011/016
.133 (3.38)
.053 (1.35)
.085 (2.16)
RG-161/U, 174,188, 316
142-0203-011/016
.133 (3.38)
.053 (1.35)
.085 (2.16)
RG-58/U, 141, 303
142-0207-011/016
.225 (5.72)
.145 (3.68)
NONE
RG-142, 223, 55, 400
142-0207-011/016
.285 (7.24)
.165 (4.19)
NONE
RG-178/U, 196
142-0102-401/406
.133 (3.38)
.053 (1.35)
.085 (2.16)
142-0103-401/406
.133 (3.38)
.053 (1.35)
.085 (2.16)
RG-58/U, 141, 303
142-0107-401/406
.225 (5.72)
.145 (3.68)
NONE
142-0107-401/406
.285 (7.24)
.165 (4.19)
NONE
250
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“142-0203-016”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+214.650881+27.80480
- 10+182.4276810+23.63077
- 25+171.0032125+22.15090
- 50+162.8440950+21.09401
- 100+155.07567100+20.08773
- 250+145.37582250+18.83126
- 500+138.44643500+17.93366
