SMB 3-Piece Straight Plugs
1. Identify connector parts. (3 piece parts):
Crimp sleeve, body assembly and contact
2. Strip cable to dimensions shown. Do not nick braid or
center conductor. Tin center conductor if contact will be
solder attached. Do not tin center conductor if contact is
to be crimp attached. Slide heat shrink (as applicable) and
crimp sleeve onto jacket of cable.
3. Assemble contact onto cable as shown. Solder
Attachment: Solder contact to center conductor through
solder hole using .015 (0.38) diameter solder. Use a
minimum amount of solder for a good joint. Crimp
Attachment: A miniature 8 indent crimp tool 140-0000970 is recommended. Crimp location should be centered
between end of contact and X-hole using positioner 1400000-971. Crimp attachment to solid center conductor
cables is not recommended.
4. Flare braid and slide body assembly over contact and
under braid. Then seat body assembly firmly onto contact.
The cable may have to be held in a clamping fixture.
Arrange braid uniformly around crimp stem. Slide crimp
sleeve forward and crimp using recommended crimp tool.
Slide heat shrink forward and shrink (as applicable).
Cable Group
Part No.
Crimp Hex
RG-316/U, 161, 174, 179, 187, 188
131-3403-021/026
.128 (3.25)
RG-316 DS, 188 DS, 179 DS
131-3404-021/026
.151 (3.83)
RG-58/U, 141, 303
131-3407-011/016
.213 (5.41)
RG-179/U, 187
131-8433-001/006
.128 (3.25)
RG-179 DS, 187 DS
131-8434-001/006
.151 (3.83)
Belden 735A
131-8445-011/016
.178 (4.52)
RG-316/U, 188, 174, 179, 187
131-9403-021
.128 (3.25)
RG-316 DS, 188 DS, 179 DS, 187 DS
131-9404-021
.151 (3.83)
252
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“131-9403-021”相匹配的价格&库存,您可以联系我们找货
