REVISION M
DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
Pb THIS PRODUCT MANUFACTURED
WITH LEAD-FREE PROCESSING
SMA-P-C-X-ST-CA1
TERMINATION
-CA1: CABLE
(RG174 OR RG316)
GENDER
-P: PLUG
DO NOT
SCALE FROM
THIS PRINT
TYPE
-C: CABLE
ORIENTATION
-ST: STRAIGHT
PLATING SPECIFICATION
-H: HEAVY GOLD
30µ" Au / 50µ" Ni MIN ON PIN
3µ" Au / 50µ" Ni MIN ON OUTER CONTACT
(SEE TABLE 1)
3
1
2
8.99 .354
REF
9.50 .374 REF
9.45 .372 REF
15.45 .608 REF
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. CENTER CONTACT PUSHOUT FORCE: 13.35 N [3 LB] MIN.
3. NOTE DELETED.
4. NOTE DELETED.
5. PRODUCT TO BE PACKAGED PER PACKAGING STANDARD CO-RF-WI-3040-M.
6. NOTE DELETED.
7. NOTE DELETED.
8. NOTE DELETED.
F:\DWG\MISC\MKTG\SMA-P-C-X-ST-CA1-MKT.SLDDRW
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN
MILLIMETERS [INCHES].
TOLERANCES ARE:
DECIMALS
ANGLES
.X: 0.3 [.01]
5
.XX: 0.13 [.005]
.XXX: 0.051 [.0020]
MATERIAL:
DO NOT SCALE DRAWING
SHELL,FERRULE: BRASS
CONTACT: BRASS
DIELECTRIC: PTFE
GASKET: SILICONE
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
SHEET SCALE: 3:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
SMA STRAIGHT CABLE PLUG, RG174 & RG316- 50 OHM
DWG. NO.
SMA-P-C-X-ST-CA1
BY: R MUSSER
01/22/2008
SHEET 1 OF 2
REVISION M
2.6 .102
RG-174 OR RG-316 CABLE
C
IN-PROCESS 1
STRIP AND TIN INNER CONDUCTOR
4.57±0.30 .180±.012
C
1
10.1 .40
HST-0.125-02-BLK
C
IN-PROCESS 2
ADD HEAT SHRINK TUBE AND FERRULE
20.0±2.5 .787±.098
2
0.10 .004 MAX. GAP ALLOWABLE
C
IN-PROCESS 3
SOLDER SIGNAL PIN
2.70 .106 MIN. FLARED ID
IN-PROCESS 4
FLARE SHIELD
0.92 .036 REF
REFERENCE PLANE
2.30 .091 REF TO CENTER CONTACT
IN-PROCESS 5
ADD SUB-SMA-P-C-X-ST-CA1
'A'
0.05 .002 REF
(TO INSULATOR)
REFERENCE PLANE
DETAIL 'A'
SCALE 8 : 1
3
0.25 .010 MAX. GAP ALLOWABLE
C
IN-PROCESS 6
3.25 .128 (HEX CRIMP)
(ACROSS 2 FACES)
CRIMP FERRULE
(USE RF CRIMP HAND TOOL # CAT-RF-FER-01 OR EQUIVALENT)
(USE .128 [ HEX DIE)
C
PROPRIETARY NOTE
IN-PROCESS 7
APPLY HEAT SHRINK TUBING
SHEET SCALE: 1.5:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
SMA-P-C-X-ST-CA1
BY: R MUSSER
01/22/2008
SHEET 2 OF 2
很抱歉,暂时无法提供与“SMA-P-C-H-ST-CA1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 4+64.46923
- 50+61.80921
- 100+59.41519
- 250+55.29216
- 500+50.84267
- 1000+46.71964
- 2500+40.72250
- 5000+36.51483
- 国内价格
- 1+68.91480
- 10+59.38920
- 30+53.57880
- 100+48.70800
- 国内价格 香港价格
- 1+101.010331+13.09286
- 50+72.9869750+9.46050
- 100+70.15174100+9.09300
- 国内价格 香港价格
- 2+76.939782+9.97286
