MMCX-P-P-H-ST-EM1
MMCX-P-P-H-ST-EM1
    SAMTEC(申泰)
    MMCX-P-P-H-ST-EM1
MMCX-P-P-H-ST-EM1 数据手册
REVISION D "A" DO NOT SCALE FROM THIS PRINT MMCX-P-P-X-ST-EM1 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] 4.50 .177 (REF) GENDER -P: PLUG 3.54 .139 (REF) TYPE -P: PCB 1.42 .056 (REF) 0.40 .016 (REF) "A" 3.54 .139 (REF) 2.38 .094 (REF) 2.70 .106 (REF) +0.05 TERMINATION -EM1: EDGE MOUNT ORIENTATION -ST: STRAIGHT PLATING SPECIFICATION -H: HEAVY GOLD (SEE TABLE 1) 1.60 .063 (REF) +.002 0.20 - 0.20 .008 - .008 TO CENTER CONTACT MMCX-P-P-X-ST-EM1-PIN MMCX-CRNG-001-X 1.40 .055 (REF) MMCX-P-P-ST-EM1-INS 'B' 10.21 .402 (REF) 4.46 .176 (REF) MMCX-P-P-X-ST-EM1-SHL 3.04 .120 (REF) 3.05 .120 (REF) 2.78 .109 (REF) 0.86 .034 (REF) RECOMMENDED PCB LAYOUT 4.80 3.70 2.40 1.10 0.70 .028 (REF) .189 .146 .094 .043 PCB EDGE SECTION "A"-"A" 4.55 .179 SURFACES FLUSH +/-.10 7.80 .307 0.35 .014 REF NOTES: 1. REPRESENTS A CRITICAL DIMENSION. 2. PUSHOUT FORCE FOR INSULATOR: 22.24 N [5 LB] MIN. 3. PUSHOUT FORCE FOR CENTER CONTACT: 11.12 N [2.5 LB] MIN. 4. INSERTION AND WITHDRAWAL FORCES PER 2.2.2 OF EN 122340:2002. INSERTION = 18 N[4 LB] MAX. WITHDRAWAL = 6 N[1.3 LB] MIN. / 18 N[4 LB] MAX. 4. PARTS TO BE PACKAGED IN TRAYS; IF QUANITY IS LESS THAN HALF TARY, PARTS TO BE PACKAGED IN COHESIVE FOAM. 5. RoHs COMPLIANT. 0.40 .016 DETAIL 'B' SCALE 20 : 1 F:\DWG\MISC\MKTG\MMCX-P-P-X-ST-EM1-MKT.SLDDRW UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS [INCHES]. TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: SEE TABLE 1 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 6:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: MMCX STRAIGHT, EDGE MOUNT PLUG- 50 OHM DWG. NO. MMCX-P-P-X-ST-EM1 BY: R MUSSER 12/03/2007 SHEET 1 OF 1
MMCX-P-P-H-ST-EM1 价格&库存
很抱歉,暂时无法提供与“MMCX-P-P-H-ST-EM1”相匹配的价格&库存,您可以联系我们找货
