MCX7-J-P-H-ST-SM1
MCX7-J-P-H-ST-SM1
    SAMTEC(申泰)
    MCX
MCX7-J-P-H-ST-SM1 数据手册
REVISION E DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] "A" GENDER -J: JACK 'B' +0.02 "A" TERMINATION -SM1: SURFACE MOUNT ORIENTATION -ST: STRAIGHT TYPE -P: PCB PLATING SPECIFICATION E -H: HEAVY GOLD (SEE NOTE 6 & 7) (MCX7-J-P-H-ST-SM1-SKT) (MCX7-J-P-F-ST-SM1-SHL) (MCX7-INS-001) SHELL E (MCX7-J-P-X-ST-SM1-SHL) SOCKET (MCX7-J-P-X-ST-SM1-SKT) E DETAIL 'B' SCALE 16 : 1 5.08 .200 (REF) 3.45 .136 (REF) 1.36 .054 (REF) TO CENTER CONTACT 4.06 .160 (REF) 6.76 .266 (REF) 4.58 .180 (REF) +.001 0.45 - 0.03 .018 - .001 6.00 .236 (REF) 1.42 .056 (REF) MCX7-J-P-X-ST-SM1 E 2.70 .106 (REF) TO CENTER CONTACT INSULATOR E (MCX7-INS-001) 0.00 FLUSH ±0.10 +.000 0.05 - 0.05 .002 - .002 TO CENTER CONTACT DETAIL 'C' SCALE 8 : 1 0.71 .028 (REF) SECTION "A"-"A" RECOMMENDED PCB LAYOUT 2.02 .080 (4 PLCS) 6.60 .260 (TYP) NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. PUSHOUT FORCE FOR INSULATOR: 20 N[4.5 LB] MIN. 3. PUSHOUT FORCE FOR CENTER CONTACT: 10 N [2.25 LB] MIN. 4. PARTS TO BE PACKAGED IN TRAYS; IF QUANTITY IS LESS THAN HALF TRAY, PARTS TO BE PACKAGED IN COHESIVE FOAM. 5. RoHs COMPLIANT. 6. COMPONENT PLATING DESIGNATIONS: -H: 0.00076[0.000030] (MIN) GOLD OVER 0.00127[0.000050] (MIN) NICKEL. -F: 0.00008[0.000003] (MIN) GOLD OVER 0.00127[0.000050] (MIN) NICKEL. 7. ASSEMBLY PLATING DESIGNATIONS: -H: (CENTER CONTACT)-H: (OUTER CONTACT)-F: MCX7-J-P-H-ST-SM1 (SHOWN) 1.60 .063 F:\DWG\MISC\MKTG\MCX7-J-P-X-ST-SM1-MKT.SLDDRW UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: SEE TABLE 1 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:0.2 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: TRUE 75 OHM, MCX STRAIGHT, SMT JACK DWG. NO. E MCX7-J-P-X-ST-SM1 BY: R MUSSER 02/06/2008 SHEET 1 OF 1
MCX7-J-P-H-ST-SM1 价格&库存
很抱歉,暂时无法提供与“MCX7-J-P-H-ST-SM1”相匹配的价格&库存,您可以联系我们找货
MCX7-J-P-H-ST-SM1
    • 1+30.66120
    • 10+30.05640
    • 30+29.65680
    库存:3
