PCS.01.250.DLLE31
PCS.01.250.DLLE31
    LEMO(雷莫)
PCS.01.250.DLLE31 数据手册
PCS.01.250.DLLE31 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 01 Termination type Female solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFS.01.250.DLAE31 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PCS*: Free receptacle with cable crimping Keying Circular, female Housing Material Brass (gold plated [ISO 27874]) shell, collet nut, brass latch sleeve and mid pieces Weight 1.40 g Performance Configuration 01.250 : 1 Coax (50 Ohm) Insulator Rated Current Others Endurance (Shell): 1000 mating cycles LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 DRAWINGS Dimensions A L S1 S2 mm. 5 18 4 4 in. 0,20 0,71 0,16 0,16 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
PCS.01.250.DLLE31 价格&库存
很抱歉,暂时无法提供与“PCS.01.250.DLLE31”相匹配的价格&库存,您可以联系我们找货
