ERA.0S.650.CLL
www.lemo.com
SUMMARY
# Wires
Triax
1
Image is for illustrative purpose only
Series
0S
Termination type
Female solder
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
FFA.0S.650.CLAC17
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
ERA*: Fixed receptacle, nut fixing
Keying
Circular, female
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
4.57 g
Performance
Configuration
0S.650 : 1 Triax (50 Ohm)
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
6 Amps
Specifications
Contact Type: Triaxial 50 Ohm (Solder)
Contact Dia.: 0.9 mm (0.035"in)
Vtest: 1200 V (AC), 1700 V (DC)
Impedance: 50 Ohm
VSWR: 1.03 + 0.34 * f/GHz
Cable type: RGT 178, RGT 174
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
E
L
M
S1
S3
e
mm.
10
12.5
7
18.5
1.2
8.2
11
M9x0.6
in.
0,39
0,49
0,28
0,73
0,05
0,32
0,43
RECOMMENDED BY LEMO
Tools
Spanner wrench:
Socket for torque wrench DCM.0S.M09.4
2/3
3/3
很抱歉,暂时无法提供与“ERA.0S.650.CLL”相匹配的价格&库存,您可以联系我们找货
