FFY.00.250.NTAC52
FFY.00.250.NTAC52
    LEMO(雷莫)
    FFY.00.250.NTAC52
FFY.00.250.NTAC52 数据手册
FFY.00.250.NTAC52 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 4.60 - 5.00 mm Status active Matching parts ERA.00.250.NTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFY*: Straight plug with cable collet Keying Circular, male Housing Material Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces Weight 7.78 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Cable type: RG 58 C/U Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >144 hr DRAWINGS Dimensions A L M mm. 8.9 33 25 in. 0,35 1,30 0,98 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.0B.ZZZ.PA070 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
FFY.00.250.NTAC52 价格&库存
很抱歉,暂时无法提供与“FFY.00.250.NTAC52”相匹配的价格&库存,您可以联系我们找货
