ERN.1S.650.CTL
ERN.1S.650.CTL
    LEMO(雷莫)
    ERN.1S.650.CTL
ERN.1S.650.CTL 数据手册
ERN.1S.650.CTL www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 1S Termination type Female solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.1S.650.CLAC47 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ERN*: Fixed receptacle, nut fixing, with grounding tab Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 8.73 g Performance Configuration 1S.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Contact Dia.: 0.9 mm (0.034in) Vtest: 1200 V (AC), 1700 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.17 * f/GHz Cable type: RGT 178, RGT 174,Belden 9222 Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.1S.M12.4 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
ERN.1S.650.CTL 价格&库存
很抱歉,暂时无法提供与“ERN.1S.650.CTL”相匹配的价格&库存,您可以联系我们找货
