FFA.1S.250.CTAC52
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
1S
Termination type
Male solder Coaxial
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
4.20 - 5.20 mm
Status
active
Matching parts
ERA.1S.250.CTL
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FFA*: Straight plug, cable collet
Keying
Circular, male
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
13.86 g
Performance
Configuration
1S.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
12 Amps
Specifications
Contact Type: Coaxial 50 Ohm (Solder)
Contact Dia.: 1.6 mm (0.063in)
Bucket Dia.: 1.4 mm (0.055in)
Vtest: 3000 V (AC), 4200 V (DC)
Impedance: 50 Ohm
VSWR: 1.01 + 0.23 * f/GHz
Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
L
M
S2
mm.
12
42.5
31.5
8.5
in.
0,47
1,67
1,24
0,33
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.1S.ZZZ.PA085
2/3
Cables
158480
PUR
Black
158490
PVC
Black
CCX.50.088.292495N
PVC
Black
CCX.50.RG5.8CU50N
PVC
Black
3/3
很抱歉,暂时无法提供与“FFA.1S.250.CTAC52”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+243.98579
- 5+239.00798
- 25+228.19842
- 50+221.18990
- 国内价格 香港价格
- 1+161.569811+20.52570
- 国内价格 香港价格
- 1+307.264501+39.40998
- 10+261.1368610+33.49361
- 25+244.7861425+31.39646
- 50+233.1096850+29.89882
- 100+221.99291100+28.47298
- 250+208.11175250+26.69257
