Description
Body
Socket
Pin Insulator
Washer
Nut
Spacer
Shield Sleeve
Retaining Nut
Crimp Ring
Heat Shrink
Material
Brass
BE CU
PTFE
Brass
Brass
PTFE
Brass
Brass
Brass
Polyolefin
Finish
Nickel
Gold
N/A
Nickel
Nickel
N/A
Nickel
Nickel
Nickel
Black
REVISIONS
0.126
[3.20]
0.272
[6.90]
0.276
[7.00]
REV
RG-58 Cable
B
DESCRIPTION
Updated footprint and dimensions; Added new title block
1/4-36UNS-2A
THREADS
0.065
[1.65]
HEAT SHRINK
Ø0.049
[1.24]
Ø0.177
[4.50]
0.354
[9.00]
0.446
[11.40]
0.020
[0.50]
0.636
[16.30]
WASHER
0.996
[25.30]
WASHER
PIN INSULATOR
RECOMMENDED
MOUNTING HOLE
RETAINING NUT
SPACER
CRIMP RING
SOCKET
SHIELD SLEEVE
MAIN BODY
6.
7.
8.
Strip cable to recommended dimensions.
Slip heat shrink and crimp ring onto stripped cable.
Insert the stripped cable through the retaining nut, shield sleeve,
and spacer.
Solder the socket to the center conductor.
Insert the socket into the pin insulator, then screw the main body onto
the retaining nut.
Wrap the braid around the tail of the body and crimp the ring with a
0.213” hex crimp tool (or one labeled for use with RG-58 cable).
Use heat shrink to cover crimp.
Use the nut and washer to secure the connector to a case.
STRIPPED CABLE
SHRINK WRAP
NOTES: (UNLESS OTHERWISE SPECIFIED)
1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE.
4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM.
2. DIMENSIONS APPLY AFTER FINISHING.
: THIS DRAWING CONTAINS PROPRIETARY INFORMATION
159 ORT LANE
CONSMA005 ASSEMBLY INSTRUCTIONS
4.
5.
0.035
[0.90]
SPACER
0.234
[6.00]
SIDE VIEW
1.
2.
3.
Ø0.177
[4.50]
Ø0.254
[6.50]
SOCKET
0.276
[7.00]
NUT
NUT
BPM
Ø0.287
[7.30]
H0.315
[8.00]
1/4-36UNS-2B
THREADS
29-JUN-12
Ø0.256
[6.50]
CRIMP RING
Ø0.402
[10.20]
APPV
0.984
[25.00]
0.500
[12.70]
RECOMMENDED CABLE STRIPPING DIMENSIONS
DATE
THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE
TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS
DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE
EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS
DESIGNATED AGENTS.
MATERIAL:
FINISH:
PROJECTION:
TOLERANCES:
.020 [0.50]-.200 [5.00]= .008 [0.20]
.200 [5.00]-1.200 [30.00]= .016 [0.40]
1.20 [30.0]-4.75 [120.0]= .024 [0.60]
4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1
TITLE:
MERLIN, OR 97532
SMA FEMALE BULKHEAD MOUNT
CABLE END CRIMP FOR RG58 CABLE
SIZE DWG. NO.
DRAWN: B.MURPHY DT: 29-JUN-12
ENGR: S.HOGAN
DT: 29-JUN-12 SCALE: 2:1
REV
CONSMA005-R58
DO NOT SCALE DRAWING
B
SHEET 1 OF 1
LDCFDLT_A
很抱歉,暂时无法提供与“CONSMA005-R58”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+55.09080
- 200+21.97800
- 500+21.24360
- 1000+20.88720
