REVISION Q
Pb THIS PRODUCT MANUFACTURED
WITH LEAD-FREE PROCESSING
MMCX-P-C-XX-ST-CA1
DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
GENDER
-P: PLUG
DO NOT
SCALE FROM
THIS PRINT
TERMINATION
-CA1: CABLE
(RG174 OR RG316)
TYPE
-C: CABLE
ORIENTATION
-ST: STRAIGHT
PLATING SPECIFICATION
-H: 30µ" GOLD CENTER CONTACT,
3µ" GOLD OUTER CONTACT
-HN: 30µ" GOLD CENTER CONTACT,
100µ" NICKEL OUTER CONTACT
(SEE TABLE 1)
1
3
0.80 .031 REF
2
3.90 .154
REF
4.00 .157
REF
6.00 .236 REF
7.00 .276 REF
13.05 .514 REF
FIG 1
MMCX-P-C-XX-ST-CA1-MKT SHOWN
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. PUSHOUT FORCE FOR CENTER CONTACT: 11.12 N [2.5 LB] MIN.
3. NOTE DELETED.
4. NOTE DELETED.
5. PRODUCT TO BE PACKAGED PER PACKAGING STANDARD CO-RF-WI-3040-M.
6. NOTE DELETED.
7. NOTE DELETED.
8. NOTE DELETED.
F:\DWG\MISC\MKTG\MMCX-P-C-XX-ST-CA1-MKT.SLDDRW
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN
MILLIMETERS [INCHES].
TOLERANCES ARE:
DECIMALS
ANGLES
.X: 0.3 [.01]
5
.XX: 0.13 [.005]
.XXX: 0.051 [.0020]
MATERIAL:
DO NOT SCALE DRAWING
SHELL, FERRULE: BRASS
CONTACT: BRASS
DIELECTRIC: PTFE
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
SHEET SCALE: 4:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
MMCX STR CABLE PLUG, RG174 & RG316- 50 OHM
DWG. NO.
MMCX-P-C-XX-ST-CA1
BY: R MUSSER
02/06/2008
SHEET 1 OF 2
REVISION Q
RG-174 OR RG-316 CABLE
C
2.00±0.30 .079±.012
IN-PROCESS 1
STRIP AND TIN INNER CONDUCTOR
C
2.50±0.20 .098±.008
C
1.55 .061 REF
TO INSULATOR
7.45±0.20 .293±.008
HST-0.125-02-BLK
3
20.0±2.5 .787±.0984
IN-PROCESS 2
ADD HEAT SHRINK TUBE AND FERRULE
0.40 .016
REF
+0.15
+.006
0.10 - 0.10 .004 - .004
(TO CENTER CONTACT)
DETAIL 'A'
SCALE 8 : 1
0.10 .004 MAX GAP ALLOWABLE C
2
IN-PROCESS 3
SOLDER SIGNAL PIN
2.70 .106
(MIN. FLARED ID)
IN-PROCESS 4
FLARE SHIELD
1
IN-PROCESS 5
ADD SUB-ASSEMBLY
'A'
CRITICAL DIMENSION INSPECTION INSTRUCTION TABLE
0.25 .010 MAX GAP ALLOWABLE C
IN-PROCESS 6
CRIMP FERRULE
3.45 .136 HEX CRIMP C
(ACROSS 2 FACES)
ASSEMBLY OPERATION
IN-PROCESS INSPECTION
STRIP AND TIN INNER
CONDUCTOR
C101, C102, C103
SOLDER SIGNAL PIN
C104
CRIMP FERRULE
C105, C106
(USE RF CRIMP HAND TOOL
# CAT-RF-FER-01)
(USE .128" HEX DIE)
0.6 .03 MAX GAP ALLOWABLE
IN-PROCESS 7
APPLY HEAT SHRINK TUBING
PROPRIETARY NOTE
SHEET SCALE: 1:0.666667
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
MMCX-P-C-XX-ST-CA1
BY: R MUSSER
02/06/2008
SHEET 2 OF 2
很抱歉,暂时无法提供与“MMCX-P-C-H-ST-CA1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+36.73080
- 10+35.92080
- 30+35.38080
- 国内价格
- 7+34.12081
- 50+32.74244
- 100+31.37615
- 250+29.23605
- 500+26.32212
- 1000+22.88827
- 2500+19.45443
- 5000+17.14505
