MCX-P-C-H-ST-CA1
MCX-P-C-H-ST-CA1
    SAMTEC(申泰)
    MCX
MCX-P-C-H-ST-CA1 数据手册
REVISION J Pb THIS PRODUCT MANUFACTURED MCX-P-C-XX-ST-CA1 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] WITH LEAD-FREE PROCESSING GENDER -P: PLUG DO NOT SCALE FROM THIS PRINT TERMINATION -CA1: CABLE (RG174 OR RG316) TYPE -C: CABLE ORIENTATION -ST: STRAIGHT PLATING SPECIFICATION -H: 30µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT -HN: 30µ" GOLD CENTER CONTACT, 100µ" NICKEL OUTER CONTACT (SEE TABLE 1) 3 1 0.90 .035 REF 2 3.90 .154 REF 4.90 .193 REF 7.00 .276 REF 9.60 .378 REF 15.70 .618 REF FIG1 MCX-P-C-XX-ST-CA1 SHOWN F:\DWG\MISC\MKTG\MCX-P-C-XX-ST-CA1-MKT.SLDDRW NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. CENTER CONTACT PUSHOUT FORCE: 10 N [2.25 LB] MIN. 3. NOTE DELETED. 4. NOTE DELETED. 5. PRODUCT TO BE PACKAGED PER PACKAGING STANDARD CO-RF-WI-3040-M. 6. NOTE DELETED. 7. NOTE DELETED. 8. NOTE DELETED. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS [INCHES]. TOLERANCES ARE: DECIMALS PROPRIETARY NOTE * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS ANGLES .X: 0.3 [.01] 5° .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: * THIS DOCUMENT CONTAINS CONFIDENTIAL AND AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHELL, FERRULE: BRASS CONTACT: BRASS DIELECTRIC: PTFE SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: MCX STRAIGHT CABLE PLUG, RG174 & RG316- 50 OHM DWG. NO. MCX-P-C-XX-ST-CA1 BY: R MUSSER 02/06/2008 SHEET 1 OF 2 REVISION J C 2.40±0.30 .094±.012 RG-174 OR RG-316 CABLE IN-PROCESS 1 STRIP AND TIN INNER CONDUCTOR C 3.80±0.30 .150±.012 8.50±0.30 .335±.012 2.95 .116 REF TO INSULATOR C 3 HST-0.125-02-BLK 20.0±2.5 .79±.10 IN-PROCESS 2 ADD HEAT SHRINK TUBE AND FERRULE 0.52 .020 (REF) 0.10 .004 MAX GAP ALLOWABLE C 2 IN-PROCESS 3 SOLDER SIGNAL PIN 0.20 .008 REF MIN TO CENTER CONTACT DETAIL 'A' SCALE 8 : 1 2.70 .106 (MIN. FLARED ID) IN-PROCESS 4 FLARE SHIELD 1 IN-PROCESS 5 ADD SUB-ASSEMBLY (USE FIXTURE AS REQUIRED TO ASSURE CENTER CONTACT PIN LOCATION) 'A' C 0.25 .010 MAX GAP ALLOWABLE IN-PROCESS 6 CRIMP FERRULE (USE RF CRIMP HAND TOOL # CAT-RF-FER-01 OR EQUIVALENT) 3.45 .136 HEX CRIMP C (ACROSS ALL FACE) * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, 0.60 .024 MAX GAP ALLOWABLE INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY IN-PROCESS 7 APPLY HEAT SHRINK TUBING OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:0.666667 F:\DWG\MISC\MKTG\MCX-P-C-XX-ST-CA1-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: MCX STRAIGHT CABLE PLUG, RG174 & RG316- 50 OHM DWG. NO. MCX-P-C-XX-ST-CA1 BY: R MUSSER 02/06/2008 SHEET 2 OF 2
MCX-P-C-H-ST-CA1 价格&库存
很抱歉,暂时无法提供与“MCX-P-C-H-ST-CA1”相匹配的价格&库存,您可以联系我们找货
