MMCX-P-P-H-ST-SM1
MMCX-P-P-H-ST-SM1
    SAMTEC(申泰)
    MMCX-P-P-H-ST-SM1
MMCX-P-P-H-ST-SM1 数据手册
REVISION 0 "A" DO NOT SCALE FROM THIS PRINT MMCX-P-P-X-ST-SM1 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] GENDER -P: PLUG 4.50 .177 (REF) TYPE -P: PCB 3.50 .138 (REF) "A" +0.05 ORIENTATION -ST: STRAIGHT PLATING SPECIFICATION -H: HEAVY GOLD (SEE TABLE 1 ) 0.40 .016 (REF) 2.38 .094 (REF) TERMINATION -SM1: SURFACE MOUNT 1.60 .063 (REF) +.002 0.20 - 0.20 .008 - .008 TO CENTER CONTACT MMCX-P-P-X-ST-SM1-PIN MMCX-CRNG-001 1.40 .055 (REF) 2.80 .110 (REF) MMCX-INS-006 'C' 5.35 .211 (REF) 2.55 .100 (REF) MMCX-P-P-X-ST-SM1-SHL 1.00 .039 REF 0.70 .028 (REF) END OF CENTER CONTACT NOT TO PROTRUDE BEYOND ENDS OF LEGS. 0.75 .030 TYP REF SECTION "A"-"A" RECOMMENDED PCB LAYOUT SURFACES FLUSH +/-.10 1.30 .051 5.40 .213 0.75 .030 TYP REF 1.30 .051 (TYP) 2.00 .079 (4 PLCS) REF NOTES: 1. REPRESENTS A CRITICAL DIMENSION. 2. PUSHOUT FORCE FOR INSULATOR: 22.24 N [5 LB] MIN. 3. PUSHOUT FORCE FOR CENTER CONTACT: 11.12 N [2.5 LB] MIN. 4. INSERTION AND WITHDRAWAL FORCES PER 2.2.2 OF EN 122340:2002. INSERTION = 18 N[4 LB] MAX. WITHDRAWAL = 6 N[1.3 LB] MIN. / 18 N[4 LB] MAX. 4. PARTS TO BE PACKAGED IN TRAYS; IF QUANITY IS LESS THAN HALF TARY, PARTS TO BE PACKAGED IN COHESIVE FOAM. 5. RoHs COMPLIANT. 4.20 .165 (TYP) DETAIL 'C' SCALE 20 : 1 2.70 .106 F:\DWG\MISC\MKTG\MMCX-P-P-X-ST-SM1-MKT.SLDDRW UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS [INCHES]. TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: SEE TABLE 1 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 6:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: MMCX STRAIGHT, SMT PLUG- 50 OHM DWG. NO. MMCX-P-P-X-ST-SM1 BY: R MUSSER 12/03/2007 SHEET 1 OF 1
MMCX-P-P-H-ST-SM1 价格&库存
很抱歉,暂时无法提供与“MMCX-P-P-H-ST-SM1”相匹配的价格&库存,您可以联系我们找货
MMCX-P-P-H-ST-SM1
    • 1+140.06520
    • 10+134.55720
    • 30+125.02080
    库存:24
