MCX-J-P-H-ST-MT1
MCX-J-P-H-ST-MT1
    SAMTEC(申泰)
    MCX
MCX-J-P-H-ST-MT1 数据手册
REVISION B MCX-J-P-X-ST-MT1 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] 0.40±0.05 .016±.002 GENDER -J: JACK C1 B DETAIL 'C' SCALE 10 : 1 TERMINATION -MT1: MIXED TECHNOLOGY TYPE -P: PCB ORIENTATION -ST: STRAIGHT PLATING SPECIFICATIONS -H: HEAVY GOLD (SEE NOTE 6 & 7) (MCX-J-P-F-ST-MT1-SHL) (MCX-J-P-ST-MT1-INS) (MCX-J-P-H-ST-SM1-SKT) 2.78 .109 REF (TO INSULATOR) REFERENCE PLANE 8.00 .315 REF 2.79 .110 REF (TO CENTER CONTACT) DETAIL 'B' SCALE 10 : 1 4.50 .177 REF MCX-J-P-X-ST-MT1-SKT "A" MCX-J-P-ST-MT1-INS MCX-J-P-X-ST-MT1-SHL 4.10 .161 REF 'B' 6.00 .236 REF 8.70 .343 REF +0.01 +.000 0.09 - 0.09 .004 - .004 TO CENTER CONTACT C2 0.38 .015 REF 'D' FIG.1 MCX-J-P-X-ST-MT1 SHOWN "A" 0.92 .036 REF 2.70 .106 REF RECOMMENDED PCB LAYOUT SECTION "A"-"A" 1.44 .057 REF 0.92 .036 REF +0.15 +.006 0.02 - 0.05 .001 - .002 C3 1.40 .055 (THRU 4 PLCS) 5.08 .200 1.10 .043 (SOLDER PASTE) 6.00 .236 REF 5.08 .200 REF DETAIL 'D' SCALE 25 : 1 5.08 .200 F:\DWG\MISC\MKTG\MCX-J-P-X-ST-MT1-MKT.SLDDRW NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. PUSHOUT FORCE FOR INSULATOR: 20 N [4.5 LB] MIN. 3. PUSHOUT FORCE FOR CENTER CONTACT: 10 N [2.25 LB] MIN. 4. PRODUCT TO BE PACKAGED PER PACKAGING STANDARD CO-HD-WI-3040-M. 5. RoHs COMPLIANT. 6. PLATING: -H: 0.000030" MIN. GOLD OVER 0.000050" MIN. NICKEL. -F: 0.000003" MIN. GOLD OVER 0.000050" MIN. NICKEL. 7. ASSEMBLY PLATING DESIGNATIONS: -H: (CENTER CONTACT)-H (OUTER CONTACT)-F UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS [INCHES] TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING CONTACT: COPPER ALLOY SHELL: BRASS DIELECTRIC: PTFE SHEET SCALE: 5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: MCX, STRAIGHT JACK, MIXED TECHNOLOGY - 50 OHM DWG. NO. BY: MCX-J-P-X-ST-MT1 T. MEEK 02/12/2010 SHEET 1 OF 1
MCX-J-P-H-ST-MT1 价格&库存
很抱歉,暂时无法提供与“MCX-J-P-H-ST-MT1”相匹配的价格&库存,您可以联系我们找货
MCX-J-P-H-ST-MT1
    • 1+55.371381+7.19810
    • 10+47.4611910+6.16980
    • 50+30.3369150+3.94370
    • 100+29.55459100+3.84200
    • 500+29.29381500+3.80810
    • 1000+29.033031000+3.77420
    • 2000+28.859182000+3.75160
    库存:4
    MCX-J-P-H-ST-MT1
    • 1+51.362311+6.67694
    • 50+43.2670750+5.62458
    • 100+35.17045100+4.57205
    • 500+23.08283500+3.00070
    • 1000+20.483891000+2.66284
    • 2000+19.585202000+2.54602
    库存:4833
