REVISION C
MCX7-J-P-XX-RA-TH1
DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
'B'
DO NOT
SCALE FROM
THIS PRINT
GENDER
-J: JACK
TYPE
-P: PCB
+.001
+0.02
.018
0.45
- .001
- 0.03
"A"
3.50 .138
(REF)
DETAIL 'B'
SCALE 16 : 1
9.20 .362
(REF)
5.08 .200
(REF)
-HN: HEAVY GOLD/NICKEL (SEE NOTE 5 & 6)
(MCX7-J-P-H-RA-TH1-SKT)
(MCX-SHL-001-F)
(MCX7-J-P-N-RA-TH1-BDY)
+.004
.054 - .002
TO CENTER CONTACT
0.50 .020
(REF)
2.70 .106
(REF)
0.79 .031
(REF)
+0.10
1.36 - 0.05
TERMINATION
-TH1: THROUGH HOLE
ORIENTATION
-RA: RIGHT ANGLE
PLATING SPECIFICATION
-H: HEAVY GOLD (SEE NOTE 5 & 6)
(MCX-SHL-001-F)
(MCX7-J-P-F-RA-TH1-BDY)
2.70 .106 (REF)
TO CENTER CONTACT
0.92 .036
(REF)
"A"
DETAIL 'C'
SCALE 8 : 1
4.50 .177
(REF)
3.45 .136 (REF)
SHELL
(MCX-SHL-001-X)
SOCKET
(MCX7-J-P-X-RA-TH1-SKT)
4.06 .160
(REF)
6.50 .256
(REF)
INSULATOR 1
(MCX7-J-P-RA-TH1-INS)
MCX7-J-P-H-RA-TH1
(SHOWN)
INSULATOR 2
(MCX7-INS-002)
C3 9.50±0.10 .374±.004
FLUSH ±0.10
6.00 .236 (REF)
RECOMMENDED PCB LAYOUT
1.40 .055
(4 PLCS)
BODY
(MCX7-J-P-X-RA-TH1-BDY)
NOTES:
1.50 .059
(REF)
1. C REPRESENTS A CRITICAL DIMENSION.
2. PUSHOUT FORCE FOR INSULATOR: 20 N[4.5 LB] MIN.
3. PARTS TO BE PACKAGED IN TRAYS; IF QUANTITY IS LESS THAN HALF
TRAY, PARTS TO BE PACKAGED IN COHESIVE FOAM.
4. RoHs COMPLIANT.
5. COMPONENT PLATING DESIGNATIONS:
-H: 0.00076[0.000030] (MIN) GOLD OVER 0.00127[0.000050] (MIN) NICKEL.
-F: 0.00008[0.000003] (MIN) GOLD OVER 0.00127[0.000050] (MIN) NICKEL.
-N: 0.00254[0.000100] (MIN) NICKEL.
6. ASSEMBLY PLATING DESIGNATIONS:
-HN: (CENTER CONTACT)-H:
(OUTER CONTACT)-F:
(REMAINING METAL PARTS)-N:
-H: (CENTER CONTACT)-H:
(OUTER CONTACT)-F:
(REMAINING METAL PARTS)-F:
3.20 .126 (TO CENTER CONTACT)
SECTION "A"-"A"
SCALE 4 : 1
5.08 .200
5.08 .200
F:\DWG\MISC\Mktg\MCX7-J-P-XX-RA-TH1-MKT.SLDDRW
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
ANGLES
.X: 0.3 [.01]
2
.XX: 0.13 [.005]
.XXX: 0.051 [.0020]
MATERIAL:
1.10 .043
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 5:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
MCX RIGHT ANGLE, THROUGH HOLE JACK- 75 OHM
DWG. NO.
MCX7-J-P-XX-RA-TH1
BY: R MUSSER
02/06/2008
SHEET 1 OF 1
很抱歉,暂时无法提供与“MCX7-J-P-HN-RA-TH1”相匹配的价格&库存,您可以联系我们找货
